968 Forum 1992-1995
993 headlight conversion
Old 03-14-2015, 05:08 PM
  #31
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
hi Benji,
I have to admit that's quite a helping of humble pie you've just served up there!!!
I can't say enough what a difference it makes to see them mounted on board a 968.
they're very different from mine.... but, I must say - that looks damn good.
I've been saying through and through; that the rise needs to be higher.
clearly, that's a signature opinion that I can't back away from. I won't.
obviously, if I did, it would only make my predicament (as a critic of the design) even worse.
just the same, it's hard to talk and eat humble pie with my foot in my mouth.
but seeing them on one of the cars clearly makes this issue less problematic for me.
nice work.
od.
Originally Posted by 951rs
are you aware of the product specifications?
I was only going by what Mark posted:
as the current fenders had been set up to run with the lenses only.
I wasn't aware of that having changed.
Old 03-14-2015, 05:48 PM
  #32
Jay Wellwood
Jay Wellwood's Avatar
Regardless of approach, the end results speak for themselves IMHO.
Still a HUGE improvement over the Sprite Bug-Eye look the 968 (and 928) OEM equipment.
Old 03-11-2017, 08:33 PM
  #33
Jay Wellwood
Default 2 years later...
After nearly 2 years since I first created this thread I've managed to accumulate some parts and took a few photos and made a few measurements today.
In reflection I'm inclined to believe after all of this investigation that if the fenders don't have some form of 'hump', the end user will not have properly aligned/aimed headlights and likely never will be satisfied with the aim of them.
I'll add photos with captions thru a series of posts as I'm a dolt when it comes to inserting comments between pics.
First, a few pics of the bottom of the 993 and 968 fenders.
Old 03-11-2017, 08:34 PM
  #34
Jay Wellwood
A side by side view...
Old 03-11-2017, 08:36 PM
  #35
Jay Wellwood
Note the slightly different headlight opening curvatures - particularly the end line of the 968 and the flared opening of the 993.
Old 03-11-2017, 08:38 PM
  #36
Jay Wellwood
As previously mentioned in another related thread, there is a leveling motor in the 993 HL assembly which is operated by a switch on the dash.
There is a level built into the 993 HL housing.
Old 03-11-2017, 08:41 PM
  #37
Jay Wellwood
I seperated the lens from the HL housing and placed it in the 968 fender opening for reference.
Note the obvious relative height differences between the 993 and the 968 headlight opening. Rough measurements taken indicate ~1" difference in height.
Based on this observation, unless there is a 'hump' in the fender, I suspect that the 993 headlight will likely never achieve proper aiming.
Old 03-12-2017, 12:56 PM
  #38
Jay Wellwood
Default I stand corrected
So, while there is a level indicator in the 993 HL as shown above, I noted in reviewing the 993 PET that perhaps the leveling of the HL's might not be found in all cars. The switch and the small motor are together listed as parts of option code M605. Since it is listed as an option code, perhaps it wasn't applied as a standard universal part of the cars.
Regardless, based on the conclusions I offered up previously - the proper fitment will likely require the hump.
OD's pics shared...
Old 03-12-2017, 04:17 PM
  #39
Boeing 717
Registered User
Boeing 717's Avatar
Thanks for doing that Jay. I was thinking of buying a 993 lens to see, now I don't have to.
Old 04-04-2017, 08:38 PM
  #40
car_slave
car_slave's Avatar
I got a great deal on a set of 993 lenses so figured I'd give it a shot on my track car. They sort of fit but I had to use silicone to fill the gaps - which is fine for race car with nonfunctioning lights but I wouldn't bother with a street machine.
Those are my rain tire wheels
Old 04-05-2017, 09:33 PM
  #41
odurandina
Team Owner
odurandina's Avatar
you have to do sheet metal work plus badass body sculpting.....
the hump is HUGE compared to oem.... and yes, there really is NO OTHER WAY (sorry)
but, you will love yourself (and hate Porsche for designing the 968's fenders/fixed headlamp setup properly in 1991).
Old 03-28-2018, 05:20 PM
  #42
odurandina
Team Owner
odurandina's Avatar
Post your headlight conversions!!
Old 03-29-2018, 10:03 AM
  #43
Boeing 717
Registered User
Boeing 717's Avatar
What's the scoop on that car OD?
Old 03-29-2018, 03:36 PM
  #44
touareg
touareg's Avatar
OD's pics shared...
You are correct, in the 80 / 90s, if I recall in europe at least it was required that cars could adjust their headlights based on load, so that you would not blind oncoming drivers, especially when hids came out.
Old 10-07-2019, 02:42 PM
  #45
PF
PF's Avatar
Default D9 fenders 993 headlights succesful
Hi.
Ok so for anyone considering or thinking about the Deutsch Nine 993 headlight conversion fenders for the 968 and if/how it works the below link is to how I did it and finally was succesful. I hope this will help anyone that is willing.
Pic of my finished car here also.
Good luck
Peder 🇸🇪
https://rennlist.com/forums/968-foru...stability.html
Quick Reply: 993 headlight conversion
