Turbo Cup 2 Rims - Winter Tires alignment Specs
Hi there,
I just purchased Blizzak WS80 winter tires for my 968 and just want to ask if anyone knows if there are any specific specs for the alignment that I can relay to the tech that is installing them next week.
Tire: Bridgestone Blizzak WS80
Rims: Turbo Cup 2 - 17"
The tires that I purchased have the following spec.
Front: 225/45r17
Rear: 235/45r17
Any help/suggestions is greatly appreciated!
Front: 225/45r17
Rear: 235/45r17
Nothing special...just your basic stock alignment.
Probably no need to change anything. What camber/castor/toe specs are you currently running, front/rear?
Are you aware of the standard daily driver 968 specs for camber/castor/toe settings?
This way I can relay them to the tech installing the tire.
