968 Forum 1992-1995
Rebuilding a 968 engine
Old 12-11-2010, 08:38 PM
Lemming
Lemming's Avatar
Default Rebuilding a 968 engine
I'm just getting started with a complete rebuild and thought that I would share pics and comments as I go. Below you have a 1994 968 block that is about to get new main bearings. More photos tomorrow.
Old 12-12-2010, 05:27 PM
Lemming
Lemming's Avatar
After cooking breakfast for the family I managed to get down into the garage to work on the engine. Inserted new main seals, added assembly lube and put the crank back in and torqued it down. Then I pulled two heads off the shelf and am in the process or cleaning them up. Will likely take one to have new valve shaft seals installed and cleaned up.
Old 12-12-2010, 06:50 PM
blue44
blue44's Avatar
I'm going to like this thread...
Donn
Old 12-12-2010, 06:57 PM
Apex Rex
Apex Rex's Avatar
I'll be following this one for sure! Thanks for posting all the pics Lemming!
Old 12-12-2010, 08:57 PM
Lemming
Lemming's Avatar
Happy to do it. Sitting here putting my shopping list together; even as a diy this stuff is expensive. Sitting here trying to decide if if is worthwhile to do the balance shaft bearings or not.
Old 12-12-2010, 10:34 PM
Apex Rex
Apex Rex's Avatar
I have to do rod bearings in my 968 motor this winter, so I'll be looking out for those pics especially!
It'll be my first time doing internal engine work, so knowing that more people can diy these is helpful.
Old 12-13-2010, 02:35 AM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Tim, can you order an extra set of rod bearings ?
Old 12-13-2010, 07:26 AM
Lord_Galva
Lord_Galva's Avatar
Donn
+1
Hey Lemming nice car!
Been away for a while and I missed a lot.
You car looks great!
Old 12-13-2010, 11:58 AM
kwikt
kwikt's Avatar
Just did my rod bearings, pan gasket and steering rack over the weekend. Wooohh very time cosuming. BTW, the Harbor Freight engine support bar is the ticket
Old 12-13-2010, 04:20 PM
968workaholic
968workaholic's Avatar
Tim, make sure the front surface where the oil pump bolts up it perfectly flat, in regards to the crank bridge and the block, or it will leak. This comes from experience Also, do the balance shaft bearings, they are cheap enough and you are already there
Old 12-13-2010, 04:31 PM
Lemming
Lemming's Avatar
Yea, read that in the service manual and it took a few good wacks with a rubber mallet to get it seated properly.
Old 12-13-2010, 04:33 PM
968workaholic
Some of them line up perfectly first time and some need some "coaxing". Have fun with the rebuild it is definitely a good experience
Old 12-14-2010, 12:30 AM
FRporscheman
FRporscheman's Avatar
I thought the girdle-to-block mating surfaces were supposed to get loctite 574, not assembly lube, is that incorrect?
Old 12-14-2010, 11:23 AM
Lemming
Lemming's Avatar
That was not in the workshop manual and when removed there was no indication of a sealant between the girdle and block. However, before I move on, I better do some more investigating. Clearly the oil pump gets loctite 574.
Old 12-14-2010, 10:27 PM
Lemming
Lemming's Avatar
Made arrangements to get the valves cleaned up and reseated. They will also check to see if it needs to be decked. I hope to have time this week to get the head to the shop. All parts should arrive tomorrow, I guess you could call this an early holiday present
Quick Reply: Rebuilding a 968 engine
