964 Turbo Forum 1989-1994
Window fuses
Old 12-14-2016, 11:05 PM
Pilotburns
Pilotburns's Avatar
Default Window fuses
Hi,
I have a 1994 964 3.6ltr turbo. First imported into USA and then into Australia and converted left to right hand drive. Recently had passenger window switch on driver's side collapse. Fitted new switch but window not working using either left or right hand switch. Checked new switch on driver's window - works fine. Can anyone tell me how many fuses control the two windows? Checked fuse box and manual. Fuse box seems to indicate 2 controllers - not sure if this refers to fuses. Box has 41 fuses in a straight line. I think fuse #4 is at least one but it checks out okay. Not sure if it is possible that the passenger window side switch would also need to be changed. Any help would be greatly appreciated.
Old 12-16-2016, 10:57 AM
Metal Guru
Metal Guru's Avatar
There should be a label on the inside of the fuse box identifying which fuse and relay does what.
Quick Reply: Window fuses
