964 Turbo Forum 1989-1994
Took delivery today
Old 11-22-2016, 07:09 PM
  #31
bonehead
bonehead's Avatar
Originally Posted by MeanMachine
Looks good ed enjoy.
Thanks Mo. But that's the before Ride height looks awful!
Old 11-23-2016, 03:00 PM
  #32
bonehead
bonehead's Avatar
Fresh off the lift. Going to go pick it up today and see if she settles some more.
Old 11-23-2016, 04:20 PM
  #33
bonehead
bonehead's Avatar
Old 11-23-2016, 05:31 PM
  #34
Vifa
Vifa's Avatar
Congrats on your car, it looks good
Old 11-23-2016, 07:35 PM
  #35
TT Surgeon
TT Surgeon's Avatar
Stunning, well done!
Old 11-24-2016, 01:49 PM
  #36
bonehead
bonehead's Avatar
Need some sage advice/opinions. Fronts definitely need spacers. Haven't measured yet, but just by eyeballing it, should I go 5 or 7mm? Do 7mm need longer bolts?
Rears are a close call. Looks pretty good but could maybe stand to be pushed out a hair?
Old 11-24-2016, 05:41 PM
  #37
Bernard
Bernard's Avatar
I've always ran 5 mm spacers front and back on both of my Turbo's with stock hardware.
Old 11-24-2016, 06:04 PM
  #38
MeanMachine
MeanMachine's Avatar
Go for 5mm up front and 3mm in the rear.
Old 11-24-2016, 08:47 PM
  #39
Igooz
Trucker
Igooz's Avatar
Looks great and congratulations.
Re Spacers: This is what cavemen like me do when it comes to wheel spacers:
+ Go to your hardware store and buy some washers (big enough for lugbolts to go through).
+ Remove one wheel and use the washers as shim on the backside of the wheel to change the offset.
+ Set the car back on the ground with the washers on the back side and see what you think. (don't drive the car like that).
+ You can stack washers to get the exact look and decide about 3mm vs. 5mm vs. 7mm, ...
Old 11-24-2016, 10:50 PM
  #40
bonehead
bonehead's Avatar
That's what I was thinking, Mo.
Clever but I'll just take my chances with buying a spacer. If it doesn't work out, I can always sell it, take a small hit and call it a lesson learned
Old 11-24-2016, 10:53 PM
  #41
bonehead
bonehead's Avatar
I've seen several of your pics on the forum and absolutely love the offset you achieved. I'm just not sure a 5 in the back would fit without some rubbing on the inner fender.
Old 11-25-2016, 02:34 AM
  #42
TT Surgeon
TT Surgeon's Avatar
I've done just that, funny.
Old 11-25-2016, 09:22 AM
  #43
Metal Guru
Metal Guru's Avatar
This is how I did it too.
I ended up at 13 mm up front, which necessitated longer studs (easy to install, btw).
When I increased the tire size up front I dropped back to 6 or 7 (have to check).
Maybe I'll screw around with 3's in the rear in spring but they are line-on-line with the wheelwell so I'm not sure what I'll gain.
Old 11-25-2016, 05:36 PM
  #44
TT Surgeon
TT Surgeon's Avatar
I think I'd use longer studs with any simple spacer.
Old 11-25-2016, 06:40 PM
  #45
bonehead
bonehead's Avatar
Do 7mm spacers need longer studs?
Quick Reply: Took delivery today
