Big Reds - Brake Sensors
Hi Guys
Sorry to be a bother again.. Hope everyone is enjoying their P cars!!
As some of you might know, I have installed Big Reds in my 964T but the bits I got came with the 928 pads for the front (928 351 940 03).
However, with the Brake Sensors (928.612.366.00), the length of the wires aren't long enough. Does anyone know if there is another brake sensor that I can use without having to change the pads? These are for the fronts.
The 928 pads have a pin going into the pads from the sensor.
I've had a look around on the site using the search function but most threads only speak about the calipers and the rotors.
Many thanks in advance for any assistance!! Have a good weekend all!!
Hsian
Hsian
Hi Guys
Hsian
Hsian
Thanks Tony
These are the ones where the sensor sticks into the pads. Unfortunately for the front Big Reds, the length of the wire from the sensor to the connection point on the axle is too short.
Will need to measure them up but I was told the minimum length was 370mm. Have not had a chance to go measure whether they would work.
Fingers crossed that 370mm is adequate and I will then be able to get my hands on those.
Finally coming to the close of the build....2 years 10 months and counting...
Thanks Tony
Interesting it has been a while since I did the brakes on my GTS but I though they used the same sensor.
Part number you need should be 99361236801 for the 2 pin design. The previous design I believe ended in 00.
