1993 Turbo 3.6 engine condition.
A few months ago I sold my 1993 Turbo 3.6 to a UK buyer. It's in very good hands and is getting a professional going over. Well actually more than a going over, it will have a bare metal glass out respray, refurbished wheels, repainted calipers and a top end rebuild.
The concept of a top end rebuild on a car that has done 105,000km or 63,000 miles still seems strange, especially as I had the car from 45,000 miles and I don't abuse my cars.
Here's what the heads look like. It looks like the valves needs a bit of work, as does one of the rockers.
Well he wants to know what the overall status of his car and taking it up to new.
Some items are not needed but its his preference.
I have a similar mileage Turbo 3.6 and I have resprayed the car, refurbished my wheels "James Dorociak",repainted my calliper and a top end rebuild .
Look carefully at the exhaust valve guide; it's worn out. Compare it to the intake guide and you will see the difference. You can also see the witness mark around the valve seat where the exhaust valve was snapping shut in an eccentric fashion; in other words, it was missing the seat and hitting the head.
Eventually the valve head would break off and destroy the engine, so it was a good catch.
John, did the new owner ask for a leakdown before buying the car? A leakdown would have caught that.
Pitted cams/rockers are fairly common and not a show stopper.
Look carefully at the exhaust valve guide; it's worn out. Compare it to the intake guide and you will see the difference. You can also see the witness mark around the valve seat where the exhaust valve was snapping shut in an eccentric fashion; in other words, it was missing the seat and hitting the head. Eventually the valve head would break off and destroy the engine, so it was a good catch. John, did the new owner ask for a leakdown before buying the car? A leakdown would have caught that. Pitted cams/rockers are fairly common and not a show stopper.
0W40.
Is New Zealand a chilly climate?
Here in the Mitten (Michigan) we can be as low as -20F (while my car is sleeping) to 95F but I drive my car (when it's running, that is ) in early spring and late fall also when it's low 40's out. I use 15W50 Mobil1 V-Twin.
Nonetheless, I'd put that guide failure down to a material issue, not an oil selection issue.
0W40. Is New Zealand a chilly climate? Here in the Mitten (Michigan) we can be as low as -20F (while my car is sleeping) to 95F but I drive my car (when it's running, that is ) in early spring and late fall also when it's low 40's out. I use 15W50 Mobil1 V-Twin. Nonetheless, I'd put that guide failure down to a material issue, not an oil selection issue.
IMHO that was caused by improper oil and infrequent oil changes. The 0-40w Mobil 1 does not have enough zinc and other additives for flat tappets. Only 15-50 Mobil 1 or other similar specification oils works in these engines.
Any 0W oil in an air-cooled engine is a recipe for disaster. Clearances are much larger than the current water cooled engines.
I doubt you have a blockage, but I'd still tear the engine down to check the bearings and cylinders due to the incorrect oil.
I still have a 964, albeit it's used frequently on the Track, not stored. I'm using Mobil 1 Racing 4T 10W 40 based on an air-cooled mechanic's recommendation. Is that suitable?
It has enough Zinc and Phosphorous, but I still prefer the 15-50 for an air-cooled. Especially for race track or hard use. Here is the spec sheet.
https://mobiloil.com/en/~/media/7038...f94e12c89.ashx
