964 Turbo Forum 1989-1994
Turbo 3.6 front calipers....same as 993tt?
Old 06-30-2010, 03:26 PM
  #31
tim911pcar
tim911pcar's Avatar
They are different I have 993 tt spindels with the big reds on my car with 3.6 turbo on the rear
Old 07-09-2010, 06:30 PM
  #32
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
There is a 1204 size front caliper which then gave way to the 1842.
http://www.braketechnology.com/car.html#porsche
Check the size difference from the dimensional dwngs.
Old 07-12-2010, 10:54 AM
  #33
cobalt
cobalt's Avatar
Received 1,928 Likes on 1,167 Posts
The 1204 pad is used on the caliper of the 1991/1992 964 turbo along with the 928 GT/S4, the 944S2/turbo M030 package cars along with the fronts of the N/A 993's. These calipers are commonly known as the medium S4 brakes since they were first used on the 928 S4. There is a slight difference in the caliper used on the 91/92 964 turbos since these used the 322x32mm rotor vs all the others which used the 304x32mm rotor.
The 1842 pad used on the Big reds was first used on the 928 GTS in black in trailing configuration with 322x32mm solid ventilated rotors. The 94 turbo was the first car to use it in red aka "big reds" in leading configuration but used the same 322x32mm rotor with cast holes. This rotor is slightly different than the one used on the 91/92 turbo. The 94 turbo rotor can be used on the 91/92 cars but not the other way around.
The 993TT used the same 1842 pad and caliper but used a different 322x32mm rotor. This newer rotor is a 2 piece design and has a 5mm shorter hat than the 94 turbo GTS version. The caliper is the same but the change in suspension components for the 993TT requires the different offset rotor.
Old 08-18-2015, 07:20 PM
  #34
boost feen
boost feen's Avatar
Im looking for big red, silver or big black front calipers for my P-car along with 965 front rotors?
Can anyone help do they have some taking up space in garage they want to sell?
Please PM me if so thanks Shawn
Quick Reply: Turbo 3.6 front calipers....same as 993tt?
