SPEED YELLOW THRILLER!!
MY 911 RUF BTR
Alrity guys, I finally managed to get my baby back from the paintshop for a complete makeover. Car has been stripped out, no careting, no ac, floorboard painted in matt black and the list goes on and on....
Yasir,
Thanks. It's speed yellow, the wheels are painted in Porsche black, I think the factory paint code is A1 plus lacquered on the centre caps.
Rey,
Will be taking pics perhaps this weekend and will post again.
Rey,
Engine components:
3.4 litre(98mm) RUF BTR/CTR1(Yellowbird) 7.5:1 compression piston/cylinder kit(Mahle) fully finned, short skirt pistons
"Euro" fuel injection (no oxygen sensor/Lambda control, and 6mm O.D. fuel lines to the injectors)
Engine balanced and blueprinted
RUF Group B Cams
Racing Valve springs with Titanium retainers
38mm billet injector blocks with Phenalic insulators
Bosch high pressure 996 GT2/044 962 Racing fuel pump
Complete engine gasket set with Viton seals
Raceware headstuds
ARP Rod Bolts
Polished cylinder head ports
K29 Ruf Hybrid Turbo
Kokeln 642 cubic inch racing long neck intercooler(polished)
Tial 46mm wastegate with 0.9 bar boost spring
Bailey Highflow Billet Diverter Valve/Blow off Valve
EVO Motosports High flow air Induction Kit, air filter housing painted in Guards red
Mille Miglia stainless steel free-flow dual outlet muffler with 4” stainless steel tail pipe
1 5/8" B&B nearly equal length stainless steel headers without heat exchangers (Based on Porsche 934 race car)
Dome-shaped, spun aluminum CIS venturi plate
Andial fuel enrichment set at 3rd step(Same as M148/RUF fuel enrichment)
3.6-3.8% CO level,24- 25 deg. ignition timing
Running on Caltex RON 98 unleaded(Super)fuel, 80 litres fuel tank capacity
Mobil 1 5W-50 Fully synthetic engine oil
Broquet Fuel Catalyst (8 x B/8T in tank units)
B&B fender mount w/Electric fan oil cooler, steel braided hoses
Custom fabricated front bumper mounted oil cooler with high-pressure oil hoses
Rear Compact oil cooler
Cool collar around oil filter
Samco silicon hoses
Zinc coated fuel lines, pulleys etc..
Polished fan ring and fan wheel
New Bosch factory injectors, fuel lines, xenon headlights, rearlights, seals etc..
Transmission/Brakes/Suspension components:
930/934 Gearbox using SWEPCO 210 oil
KEP Lightweight billet clutch(3500 pounds clamping force)
RUF short shift kit
993 twinturbo brakes(big reds) with steel braided brake line
RUF CTR1 Sport Nurburgring shocks front and rear (Bilstein)
RUF anti-roll bars/sway bars (front 23mm, rear 22mm)
Sanders engineering gun drilled tubular torsion bars (front 22mm, rear 30mm)
Strut tower brace/bar welded to body
Das Sport Weekenders Bar, approved by PCA Club Racing, stock class cars painted in matt black.
Weltmeister Monoball Camber Plates
Weltmeister steering rack spacers
Body/Cosmetics:
RUF Speedline rims(limited production) painted to Porsche black(Rear:285/40 17”x10”)(Front:235/40 17”x9”)
RUF BTR/CTR1(Yellowbird) front and rear bumpers
RUF front bumper rubber lip
Gemballa carbon fibre rear spoiler with integrated deck lid(RSR 3.8 type)
Front air inlet for oil cooler and brake ventilation
Air inlets instead of fog lamps
Factory option code XB7-Rear air ducts(for the rear brakes)
RUF pedal set
RUF instrumentation with silver bezels
964 Nappa leather style dash in yellow stiching, Billet ignition cover
Carbon Fibre instrument panel(behind gauges)
RUF 3 spoke suede steering wheel
Door trim panles as in 911 Carrera RS with leather cover and coloured handles and pull straps in Guards red
RS Guards red seat belt
Recaro A8 light weight, limited edition leather seats with new seat rails, seats back in Speed Yellow
Philips Xenon headlights, 993 Horn
Techart clear side markers
964 style windscreen wipers
Ruf CTR1(Yellowbird)/934 Aero mirrors
993 G/**** and Handbrake in Carbon Fibre finish
964 door sills with “Turbo” script
RUF factory decals
RUF BTR 3.4 Carbon fibre emblem in center console
Alpine CD player with Boston Acoustic rear speakers
No rear seats, no rear seat belts, no spare tyres, no tools, no rear windscreen wiper, no headlight washer, no sunroof, no water tank for wiper system, no fog lights,no front speakers, no carpets, no AC, no centre console
Leather roof liner
* Full car rewired and restored to factory specifications (including under carriage, full paintwork, floor board, seals etc.) All work carried out at RUF Automobiles Singapore.
RUF Group B Cams
Raceware headstuds
ARP Rod Bolts
Samco silicon hoses
RUF short shift kit
Body/Cosmetics:
RUF pedal set
RUF factory decals
Leather roof liner
awesome car, I am big Ruf fan and have been to Ruf's place in Phaffenhausen.
how much does it weigh and how does it drive on the roads of sinapore?
marty
minnesota, usa
marty
minnesota, usa
