964 Forum 1989-1994
Rear 964 alignment adjustments, Camber and Toe
Old 03-14-2017, 10:40 PM
jellonailer
jellonailer's Avatar
Got it. The old stubby allen key with racheting box end wrench technique. I have a box full of them courtesy Porsche engineering.
Old 03-19-2017, 10:33 PM
jellonailer
My '91 964 - checked alignment in the garage, not alignment machine. Also re-set ride height. Here are the numbers:
Front
Driver Passenger
Height: 125mm Height: 125mm
Camber 1.4º 1.3º
Toe (in) 30' 30' Total - 0.375" (60', 9.5mm) 30' per side by my rusty trig
Rear
Driver Passenger
Height: 227mm Height: 227mm
Camber 2.4º 2.3º
Toe (in) 0 to 1/32" total less than 1.5mm
Rake turned out to be exactly 1º per the book.
Car is on 17" BFG R1's 275/225
I'm thinking I need 2 more degrees camber on front and a little less toe-in in front. Rear is ok.
Rear amazingly if you look at my pictures of the setting was close to being on. Front ride height was between 7-14mm too low which was a problem. Measured dimension are accurate using all thread at proper points and home made alignment tire friction discs.
Any comments? Thanks
Old 03-20-2017, 12:47 AM
Spyerx
Spyerx's Avatar
Received 1,843 Likes on 1,123 Posts
More camber front. 2.5+
Less toe front. 0 to .5mm per side toe in or toe out depending what you like
As much caster as you can get without rubbing.
Rear is typically a tick less camber than what you have up front. 2.2 maybe
Rear tow 2mm per side toe in. You need that for stability.
Has car been corner balanced?
Old 03-20-2017, 12:28 PM
jellonailer
Thanks. Agree that I need 2.5+ in the front and a little less toe in front.
Car has not been corner balanced yet. I wanted to hit ride heights first at least because I may not be able to get corner balance done in time for track day. Drivers front was 14mm lower than RS, that can't help.
I will be able to get alignment done by track day. 2.7 camber front should be reasonably easy, I have camber plates
Quick Reply: Rear 964 alignment adjustments, Camber and Toe
