exhaust
Tell more
exhaust
clewett engineering is putting together a coil on plug kit for me using electromotive TECgt200 controller. just waiting for him to finish the wiring harness. a kit like this I'm just going to run the stock intake for now until I get it tune and running good than adding to it later.http://www.clewett.com/index.php?mai...roducts_id=400
What are driving restrictions with antique plates in RI? I put antique plates on my car here in VA to get6 around inspections, but use of car is restricted, for example, no driving to work.
Also, who made exhaust and how loud is it? How does it compare to primary bypass?
exhaust
here is who made the exhaust.http://www.fvd.us/us/en/Porsche-0/-1...With_Heat.html
antique plate in this state means no state inspection, 16.00 to registration. you must own another car as your daily driver. the exhaust sound like a porsche again not like an american v8. the primary bypass seem to pull harder but with this exhaust it runs so smooth. It's hard to explain but on decell now the car coast a lot better it use to slow right down before. It's a different running car now.
this company hand makes the exhaust and they ask you If it's a 3.6L or 3.8L.It takes 3 weeks to get it from Germany.
not much heat from this set up. I'm thinking of wrapping the heater box. I really don't drive in winter but I just like everything to work. If I got the converters they say you get better heat.
