Poor leakdown #'s question
how much oil is it burning?
when you did the LD did they confirm it's leaking top and not bottom?
if the bottom end doesn't need to be done and it's simply a head rebuild and you don't go crazy you can probably get in for less than 10. but, if cams are trashed, rockers done, etc etc then the pricing goes up. All sort of depends once in there
At that level leak you're probably losing as much as 50hp at top end. Car will be noticeable better when done.
Now if bottom needs to be done too.... then it gets expensive.
Find someone with another 964 and drive it to compare to yours....if they feel similar and it was my car I would leave it alone. With proper maintenance these cars can easily run 150k + miles without being opened up.
