964 Forum 1989-1994
Mexican1000 (Rothsport 964 build)
Old 02-09-2017, 02:35 PM
911Jetta
911Jetta's Avatar
It's Guards Red, with a side mounted oil tank filler cap...
Old 02-22-2017, 11:51 PM
mkd944
mkd944's Avatar
Love the project. A Rothsport Rally video montage...
Old 02-25-2017, 09:54 AM
CKutter
CKutter's Avatar
Healy/Zwart car has returned from paint and ready to go. White One
Tuthill skid plate mounted up. Does that look cool or what?
Steve Weiner mentioned that I should jump into this this thread and bring you guys up to speed. As asked above. I will try and do a nightly update every night while on the event in Mexico.
I'm the new/old guy at Rothsport, the one with the white hair. I was brought on to strip these 2 C4's down to the last bolt. I'm a G body/914 guy, so I've learned a lot.
I was around Rennlist back in the beginning. That is where my friendship with Steve Weiner began.
https://rennlist.com/forums/911-foru...-74-911-a.html
Old 02-25-2017, 10:04 AM
LM964
LM964's Avatar
Now that would be perfect... ready and waiting
Old 03-01-2017, 10:35 AM
911Jetta
911Jetta's Avatar
Zwart?!
Steve Weiner mentioned that I should jump into this this thread and bring you guys up to speed. As asked above. I will try and do a nightly update every night while on the event in Mexico...
Big thanks for the update, I know you guys are busy. We all really appreciate the pictures and learning more about these special project cars.
Wow, this is nice!
Check out the trick Exe-TC front struts on the 964Safari. 50mm shock tube with 60mm strut housing. 4-way adjustable with remote reservoirs. Their could be a little chassis reinforcement in the background also.
Old 03-03-2017, 02:24 AM
CKutter
CKutter's Avatar
Thought this was a great shot ...................
Old 03-03-2017, 02:33 AM
Spyerx
Spyerx's Avatar
Received 1,729 Likes on 1,057 Posts
You guys are building the coolest **** right now. FORGET singer give me a Roth rsr
Old 03-03-2017, 07:53 AM
LM964
LM964's Avatar
Oh yes..! As both Ferdinand's intended.
Old 03-03-2017, 01:00 PM
911Jetta
911Jetta's Avatar
+1!
Old 03-07-2017, 01:25 PM
911Jetta
911Jetta's Avatar
Holy cow, what an air box!
Old 03-07-2017, 01:29 PM
Ken D
Ken D's Avatar
That's a cooler for keeping the tequila chilled to room temp in the desert heat
Old 03-07-2017, 02:11 PM
islandsnow
islandsnow's Avatar
sweetness in this pudding
Old 03-17-2017, 12:17 AM
CKutter
CKutter's Avatar
She back on the ground and rolling ..............
Old 04-01-2017, 11:29 AM
CKutter
CKutter's Avatar
I finished up the mud flaps yesterday. I think the plan is to take Car#1 (Rothsport) to Eastern Oregon on Monday for testing. All that is left is welding together the kangaroo bars and sending them out for powder coating and me cutting and installing the poly skid pad between the heavy aluminum skid plates.
Oh yeah, I think we're adding a steel plate right under the shifter.
It's been out for a couple road tests. It sounds bitchn.
I saw a quick glance of the proposed wrap last night. Its going to blow you away.
I'll shoot a couple pictures of the car today. I have a feeling tomorrow we be my last day off till we return from Mexico, May 1st or 2nd.
Old 04-07-2017, 01:29 PM
911Jetta
911Jetta's Avatar
Love these crazy rally car details!
Facebook Post
A look from below on the 964Safari Mexican1000 chassis at Rothsport Racing.
High lift jack in custom quick release mounts in the 964Safari Mexican1000 chassis.
Low mounted gas tank!
Theirs a place for everything in the 964Safari chassis...can you recognize this part?
Anti cactus bar as well as jacking point for the hi-lift jack. The 964Safari is ready to take on the Mexican1000.
Quick Reply: Mexican1000 (Rothsport 964 build)
