964 Forum 1989-1994
Wider Wheels and larger tires for 93 turbo 964
Old 08-28-2016, 11:43 PM
Tail Flukes
Tail Flukes's Avatar
Default Wider Wheels and larger tires for 93 turbo 964
I wan to install 19x9 with 235s on front and 19x11 with 305s on the rear of my 93 turbo 964. I am told they will fit but so far no one can tell or give me the wheel offset (ET) needed for installation that will not cause suspension issues or body modifications. Might I get some help?
Old 08-29-2016, 02:23 PM
crg53
crg53's Avatar
Why not post your questions on the 964T forum, I think you will have better luck.
Old 08-29-2016, 08:19 PM
Tail Flukes
Thank you sir. I did just that about a minute ago.
Old 08-30-2016, 12:11 AM
Vandit
Vandit's Avatar
Dude, don't put 19"s on a 964...
Old 08-30-2016, 01:21 AM
Tail Flukes
Thanks, but might I ask why no 19s on my 964?
Buck
Old 08-30-2016, 01:38 AM
Vandit
Vandit's Avatar
It's a classic, it's a small car, 19"s are going to look gigantic and likely too modern. Not to mention the weight increase and handling
/ride being diminished. Modern cars get away with 19"+ (or 21" on the GT3RS) because they're massive cars and can still run a fat sidewall. You're gonna end up riding around on some 35 or 30 series rubber bands for tires.
Old 08-30-2016, 01:46 AM
Tail Flukes
Appreciate your reply. Plenty of others are pretty much of the same opinion.
TY, Buck
Old 08-30-2016, 03:24 AM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
I run 18" and it's plenty. They look pretty big. Mainly to clear my brakes. I also run 18 on my gt3rs.
My understanding is the turbo used same offsets as narrow body because the arms are different lengths.
Check my build thread for my specs. Also no way a 11 will fit on mine. Maybe a wide body you can.
Old 08-30-2016, 03:46 AM
Tail Flukes
TY sir. Nice ride. Mine is a turbo body but the more I find out the more I tend to think that 18s will stay. I've seen 964s with 19s and they look good but as someone said. I may be running on rubber bands.
Buck
Old 08-30-2016, 09:02 AM
cobalt
cobalt's Avatar
Received 1,935 Likes on 1,170 Posts
I could not respond to your request but as others said 18's are as large a dia you want to go. A few have done 19's but not without constantly waffling a wheel. You will also find your rolling dia will be hard to match.
Make sure you measure carefully as these cars can vary and when fitting wheels and tires close to the limits what works on one doesn't necessarily work on another.
GL
Quick Reply: Wider Wheels and larger tires for 93 turbo 964
