Patrick Motorsports RS Pulley install?
Hi,
I am hoping someone has done this. I have the Patrick Motorsports RS pulley kit. I have had limited luck trying to determine how it is installed. The engine is a from a 964.
Anyone got a link for the pulley removal process? Patrick Motorsports did not provide very much information. Thanks.
Please have a look here, not exact what you are looking for but
for my change it was enough input.
https://edelweiss.smugmug.com/Cars/P...echnical-Stuff
Excellent help, thanks.
I see the methods for the fan, what about the crank pulley? It looks like I will need the crank removal tool?
Edit; found this.
https://rennlist.com/forums/964-foru...oval-tool.html
I would still need the crank pulley tool that keeps it in place.
Edit; found this.
Recently completed lower pulley install , if engine is in car yes you will need special crank
holding tool , luckily I am friends with a local Porsche factory tech who loaned it to me from the dealer , some Indys likely have it .
Also entire mounting crossmember will need to be removed ,I was installing reinforced RS
unit so it had to come out anyway .
Other than that reasonably straight forward .... Bert
I think the big "wrench" is special tool 000 721 929 00. The small bolt tool is used as well.
I have read about people using the impact gun, but I will not go this route. I am guessing that it could create crank shaft stress that it was not designed for. I am trying to borrow them from a shop. If not, I will put project on hold.
Thanks for all the replies!
