heat from cat
heat from cat
Any of you guys still running a cat ?... what kind of heat do you get off it ? For some reason never paid much attention to the cat, but recently realised after a spirited run there is quite a bit of heat around the left hand rear wheel .. not sure if this has always been the case or maybe the cat is just hotter than usual
My experience has been that the cat ran hotter when I had performance chips installed. The heat caused 2 tire sidewalls to fail. I ended up putting heat tape around shield. Now have stock chip back in and haven't had a problem over life of tires.
Found this:
https://rennlist.com/forums/964-foru...exhaust-4.html
The catalytic converter heat shield looking through the left side rear wheel opening. I have measured the cat itself at well over 700 degrees. And I wouldn't be surprised if it went another couple hundred degrees above that in some situations.
I took the cat and primary out. Put the cat back in as it was too noisy and stunk badly with all the unburnt fuel. Interestingly I have never had to put a cat back on on any other vehicle due to smell (I've removed them from many bikes and performance cars over the years)
How loud is it compared to a de-cat?
I am keen to lose the cat to reduce the heat in that area but already run a cup pipe, I feel a cup pipe and decat is to loud.
Who manufacturers a decent Sport Cat for a 964?
I run a Fabspeed sport cat with no heat shielding, cup pipe, and stock secondary muffler. Not loud at all, but I get back fire "pop" every now and then. I've thought about heat wrapping the cat and cup pipe
if you're tracking the car run a bypass pipe.
Track use is very hard on the cat, generates LOTS of heat.
Removing Cat on mine didn't add much to the volume.
Basic Sponsor
If anyone is interested in a high flow Sport Cat or Catbypass pipes let me know. We have both and i'd be happy to set you up
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
