Is a proportioning valve needed for big reds on a C4?
I plan on doing big reds for my C4. 993tt front calipers, 993 rears, 965 and 951 brake rotors, etc. Going the full setup...but for those of you who did this, will I need a proportioning valve upgrade too? Or will I be ok? Thanks
I have no proportion valve on my Brembo setup (removed it), and yes parking brake works fine.
The documentation for the fitment says that you need to have at least the C4 valve which is what I'm guessing the piston bias is based on.
That said, I've locked my car up before I got the ABS working again and it still locks the fronts first (and I have the big 6 piston fronts for the 993, I have EVO uprights).
