LiFePO4 Batteries
I use a a voltphreaks. Works fine no issues.
I'm using the same as Jack Olsen, no issues here. I've had it die on me twice due to leaving my keys in the ignition over night in the on position. The other time was after installing my new alternator and fishing out some electrical issues I had to solve. I have the battery tender and used that to charge it back up. So far so good.
Thanks Vancleef. Did you have to modify your cables or the terminals? Does it hold enough charge to run the alarm system for a few of days and start OK afterward? Is it constantly on a trickle charger in your garage or do you just recharge it on occasions like you just mentioned?
The reason voltphreaks and Braille are more $ is capacity. Well and the fact the vf has a circuit that will shut down the battery if it gets low but allow enough juice for a start. Push button and Car is able to start.
Thanks guys. Good gen.
Looking at a Shorai now as an option too which looks mid price between the Deltran and voltph.
Struggling to find a reason not to run one of these but I'm surprised they're not more commonplace especially considering the life seems to be longer than a lead acid for about the same price.
Also have a voltphreaks. Im running the VPH-750 horizontally with a tiny lightweight custom fabricated bracket. Great shut off feature. Plenty powerful for the 964 unless you require serious juice for a sound system, etc...And great weight savings.
Worth the money in my opinion.
