Rothsport shifter installed
Looks really nice, can't wait to get this in mine.
Like the seats!
Rennline lower dash delete, really cleans up the dash!!!!
Like the seats!
I just drove it for the first time and you're right, I love it. It feels similar to the RS piece, but a little more weighted.
I just replaced all the bushings including the 928 ball cups. I guess you don't remember but I made my own golden rod with the brass bushings. I inspected them yesterday, zero wear and still rock solid.
I remember everything... as soon as you remind me. Must be the early onset alzheimer's.
What can I say? I have small hands, beside being ice cold today, it feels okay to me.
As far as the seats, I bought a set of nearly new pole positions from a 996 guy on here. They came in his newly acquired 996TT and he was too tall for them. His loss, my gain.
I've had the cubby sitting around for a few years now and like the idea of a spot for my wallet and phone. So I stuffed the spoiler switch behind the other switches, I never use it manually anyway. I also have a ducktail waiting to be painted, I'm still debating on that one.
Will you be a C&C?
Will you be a C&C?
Rothsport shift looks super clean but I'll be going RS shifter to keep it original looking.
I would not skimp especially if you get in there and find out the front cup is shot. I would expect that adding the other units will put more strain on any of the older components. The monoball will make it much more precise.
Thanks cobalt! I had noticed the forward rod toted a 1 inch reduction in throw as well. Can't wait for the throws to feel a lot better.
I have the billet rothsport short shifter, can anyone tell me if the extra bits from fd will fit. On their site it says custom rothsport shifter? Is it right that if i get all of it the throw gets even shorter?
FD replaces the ball at the bottom of the shifter with a threaded rod because they use end links instead of ball and cup on their forward rod. So the answer is no, it won't work with your current shifter.
Never mind. One less thing to buy for the car i guess! Thanks for the info though.
I would contact rothsport and see if the ball can be replaced with the threaded rod so it can be used with the front linkage.
I installed one of these a while ago after picking it up at Rothsport outside of Portland... BTW, genuinely good folks to deal with! Probably the nicest, single piece on the entire car.
I am sure the ball on the end of the shifter can be removed, either it will unscrew, or if it's welded on, it can be cut off. To fit the new forward rod with heim joints you just need a screw that fit the hole in the joint, and then match the thread to that in the bottom of the shifter.
