964 Forum 1989-1994
sway bar kit
Old 03-06-2016, 08:27 PM
mnmlod
mnmlod's Avatar
Default sway bar kit
OK! the PSS10's showed up yesterday. So, I've got that box checked.
I found a H & R sport sway bar kit, 24mm front and 26mm rear. Its also adjustable. Would this be a good set up for the PSS10's?
As far as bushings are concerned, should I or can go with factory Porsche? or is there a better aftermarket set?
Thanks!
Old 03-07-2016, 05:36 AM
backitoff
backitoff's Avatar
I run PSS10's (fantastic bit of kit) and have also polybushed my car.
Regarding the sway bars, I don't feel the need for upgrading them. The car sits pretty flat as is, and if anything I think a bit of weight transfer onto the respective front corner is no bad thing.
Old 03-07-2016, 06:34 AM
CRG
CRG's Avatar
oh sh*t here we go again..the good ol' Walrod vs Elephant Racing bushing debate..please don't ask about oil next, please!
if you want to go with Walrods i have a set NIB I can part with...I decided to go ER all around, will replace when the weather warms up
Old 03-07-2016, 11:16 AM
mnmlod
mnmlod's Avatar
Originally Posted by CRG
oh sh*t here we go again..the good ol' Walrod vs Elephant Racing bushing debate..please don't ask about oil next, please! if you want to go with Walrods i have a set NIB I can part with...I decided to go ER all around, will replace when the weather warms up
Do you have a part number? Why Elephant Racing over Walrod? I'm not trying to start any fights.
Old 03-07-2016, 11:19 AM
mnmlod
mnmlod's Avatar
Originally Posted by backitoff
I run PSS10's (fantastic bit of kit) and have also polybushed my car. Regarding the sway bars, I don't feel the need for upgrading them. The car sits pretty flat as is, and if anything I think a bit of weight transfer onto the respective front corner is no bad thing.
Polybushed? Who makes these and why are they better. Sorry I'm new to this bushing thing.
Old 03-07-2016, 11:43 AM
CRG
CRG's Avatar
https://rennlist.com/forums/964-foru...-bushings.html
https://rennlist.com/forums/993-foru...-bushings.html
I'm not advocatring one over the other, it's always a hot debated topic...use the search function, lots of threads
Old 03-07-2016, 04:36 PM
backitoff
backitoff's Avatar
I used Powerflex as they do the rear trailing arm bush kit and I have used Powerflex before on other cars with good results
Old 03-07-2016, 05:28 PM
mnmlod
mnmlod's Avatar
Thanks for the help.
Old 03-07-2016, 06:45 PM
Goughary
Goughary's Avatar
The h and r swaybars are great .
Elephant racing makes a sport bushing that is 25% harder than stock. They are rubber.
I'm happy to discuss...and I won't even tell you to use the search function...lol.
Old 03-07-2016, 09:30 PM
mnmlod
mnmlod's Avatar
I got the Elephant Racing Sport Bushings today. I read on here that the sway bars are not that big of a deal and that the stock ones are fine and that the bushings and the pss10's are all I really need. Anyone else disagree? I don't have a problem getting them if it'll improve things. Also, with the H&R sway bar kit, front and back, does that come with the bushings for that too? I noticed the bushings come in different sizes or the sway bar you have.
Old 03-07-2016, 11:27 PM
Goughary
Goughary's Avatar
The swaybars come w bushings.
We are using them on all the cars in the suspension madness thread. They do make a huge difference.
Old 03-08-2016, 02:23 AM
Johannvb
Johannvb's Avatar
I just ordered a set of H&R sways as well and will combine them with Bilstein B6.
Old 03-08-2016, 02:33 AM
mnmlod
mnmlod's Avatar
Sounds good
Old 03-08-2016, 10:09 PM
mnmlod
mnmlod's Avatar
OK, the H&R sway bars are ordered. New bushings are on the way along with a strut tower support bar, The pss10's are sitting on the floor next to me. Now what? Ha!
Old 03-09-2016, 03:40 PM
Goughary
Goughary's Avatar
Tarret rod-end rear drop links and sealsit boots to protect from road grime.
Monoball top hats at least in the rear.
And better spring plates to reduce or eliminate weissach effect
Quick Reply: sway bar kit
