Mild leak and odd electrical behavior
A few weeks ago when backing out of the driveway my 1989 C4 acted odd with the electrics in the car seemingly restarting (radio, radar detector, head lights). I pulled it back in the garage. Seemingly the batter had finally given up the long fight, and I replaced it with a new one. Things seemed great for another week, but last night I had some of the same behavior. One common aspect was that it was wet/raining both times. I've started to look for a leak, and found that under the passenger side, one of the wires passing through the body was slightly wet.
This morning after a wet ride, I pulled in and started to look for moisture, based on previous threads about leaks. I believe I have found that my windshield washers are the source, as both seem wet underneath. One of the previous threads mentioned cleaning the gasket that goes between the washer nozzle and the body, but I apparently do not have any gasket.
On the hope that the leak is the source of the electrical issues, is there supposed to be a gasket between the windshield washer nozzle and the body?
Mine look like:
Mine look like:
Rain may be part of the problem. But, not in as obvious way as one would expect.
The problem could be A 'lazy' alternator. The battery has been drained somewhat by being idle and wth the extra pull from the wipers, radio, lights etc on start up, the alternator doesn't generate enough boost from idle. Get the revs up a bit on start up and that problem should clear.
Quick update. A few weeks went by with no issues. Then it returned. This time the weather was bone dry. I checked and the alternator was putting out about 12V. I have since replaced the alternator and again the issue has gone away. Hopefully this was all due to that 'lazy alternator'
I'd just like to go on record that I hate electricity when it doesn't behave. A few more weeks went by with no issues. The all of the sudden it returned again with low voltage. Another look at the system found a somewhat questionable ground cable to the battery. I've replace that with a new one, and also have the trans/body ground strap to replace. Here's to hoping that was the problem. (note: I should have actually replaced these ground straps before instead of inspection but jumped right over a possible cheap solution )
Have you looked for current drain with the key out? There are a couple odd aspects of these cars that can lead to the battery draining, like for example didja know that the engine department/frunk/love department lamps are all connected? A bad or intermittent switch in any of those locations can be quite vexing.
