964 Forum 1989-1994
Rothsport vs. CAE Shifter
Old 11-24-2015, 02:03 AM
Undutched
Undutched's Avatar
CAE for me as well. Mainly because I'm a local and the car sits like 5 minutes from them.
If C4 drivers are interested I could ask him if it fits.
Old 11-24-2015, 03:49 AM
freedman
freedman's Avatar
Afraid it doesn't, I spoke to CAE a couple of weeks ago
Talking to a couple of other owners we believe there may be a way to make it work, but its far from straightforward, and not a straightforward bolt in
Old 11-24-2015, 04:27 PM
911Jetta
911Jetta's Avatar
Wow, that is a mechanical looking beast.
(I'll take one in black please)
Looks great in action:
Old 11-24-2015, 05:11 PM
kos11-12
kos11-12's Avatar
Originally Posted by freedman
Afraid it doesn't, I spoke to CAE a couple of weeks ago Talking to a couple of other owners we believe there may be a way to make it work, but its far from straightforward, and not a straightforward bolt in
Be interested to here what was the idea to try and make it work , I was also thinking of welding like an oval shape that go around the shaft ... But maybe the solution is to buy the boxter one with cables and ask a company called Ringspann in Bedford to make a plate with a system to adapt to the rod .
Old 11-24-2015, 06:06 PM
freedman
freedman's Avatar
It involved replacing one of the U shaped plates in the exisiting linkage 9lower one IIRC) with the upper one turned upside down and an RS lever, this would then attach to the CAE shift.
It was a compromise but I think would allow you to use the CAE shifter.
Was suggested by a member with more technical knowledge than myself!
https://scontent-lhr3-1.xx.fbcdn.net...0c&oe=56ADD4C8
Old 11-24-2015, 06:23 PM
kos11-12
kos11-12's Avatar
Hi Freedman ,
Thanks a lot , would have need to see it finished to understand ....
Old 11-25-2015, 05:33 PM
koenig_roland
koenig_roland's Avatar
Well,
i did this for my C4 - ruf inspired - but was not fully satisfied.
https://rennlist.com/forums/964-foru...undertray.html
The custom shifter and the secound half-pipe with fork and custom bolt is for sale... You need to re-use one of your half-pipes, need to buy 4 M6 bolts with washers and could refit the ruf short-shift to your C4 w/o modifying the undertray...
PN if interested
regards from munich :-)
Old 11-26-2015, 07:12 AM
Strega(UK)
Strega(UK)'s Avatar
Originally Posted by koenig_roland
Well,
PN if interested
That's a shame to hear. That was my inspiration. Could you tell me exactly what you weren't happy with and any other feedback?
Old 11-26-2015, 09:00 AM
koenig_roland
The shift in (or is it to?) the second gear was quite harsh/hard. The handling (length of the shifter, position with the rs-seats and the steering - fixed with 5P harness) was perfect. But - the shifting was so hard, i got aching in my right arm, when driving some hours with the car.
Shifting was so hard, that i lost time, because the shifts were extrem slow.
We used an other gear-oil, but also when the box was warmed up, it was not that good like expected. With a cold gearbox it was horrible, when driving in traffic...
I decided to refit the original shifter....
My second gear is still not that good "shiftable" like new, so i think it could be possible, that another C4 owner is happy with the short-shift solution...
regards
Quick Reply: Rothsport vs. CAE Shifter
