964 Forum 1989-1994
Help!!! Removing the oil bridge tube for chain tensioner!!!!
Old 10-27-2015, 02:05 AM
vsouvann
vsouvann's Avatar
Default Help!!! Removing the oil bridge tube for chain tensioner!!!!
I can't get this little bad boy out. I tied pulling, but it doesn't want to come out. Is it that hard to pull? Any idea to get it out? I am replacing the o rings. Name:  image.jpeg
Old 10-27-2015, 02:50 PM
NateSaJack
NateSaJack's Avatar
I'd have expected it to just pull out. Are you having the same problem on both?
Old 10-27-2015, 05:48 PM
vsouvann
vsouvann's Avatar
I tried pulling it. I was expecting it to just pop out, but it is not. Yes, both are stuck. I can wiggle it, but it won't come off. Any idea to get it out?
Old 10-27-2015, 06:09 PM
Rabs
Rabs's Avatar
Had the same issue but you just have to get a firm grip on them and pull hard. It's the seal on the other end that makes it hard to get out.
Old 10-27-2015, 07:59 PM
vsouvann
vsouvann's Avatar
Thanks. I will try it again later today.
Old 10-27-2015, 08:14 PM
tbennett017
tbennett017's Avatar
I put a rag around it and grabbed it with some channel-lok pliers and tugged it out. It's the O-ring inside that needs to come loose.
Old 10-28-2015, 11:58 PM
vsouvann
vsouvann's Avatar
Ahhh! Finally got it out. I wrapped it with a rag and Thanks everyone.
Quick Reply: Help!!! Removing the oil bridge tube for chain tensioner!!!!
