Clutch MAster/Slave Qustion
I have a minor issue with clutch pressure/ volume of fluid pushed by the Master. I have been playing around with the Clutch Master and Slave cylinders to try and reduce pedal pressure and open significant enough volume of fluid to depress the clutch bearing completely. I can get the clutch to disengage with then standard configuration but I have high clutch pedal pressure ( works) . But the disengage point is at the bottom of travel- I have tried a different slave, which reduced pedal pressure but does not completely disengage clutch satisfactory. Slave requires more fluid.
I need to increase the volume of fluid going to the slave to raise the release point on the pedal. I don't see any way of changing setting on the master or clutch pedal mechanicals to do this
Has anyone found a solution to this - different Master - which one??
Looking for a little technical assistance/ advice.IDEAs?/
IHI KING!
Gus - Have you checked your clutch pedal travel stop and the roll pin? I had a similar problem and in my case, it was a problem with the angle that the clutch pedal was drilled. I'll try to find the thread about it.
Found it - https://rennlist.com/forums/964-foru...ake-pedal.html
Thanks for the post - but this is not the issue - I have just done a complete rebuild on clutch pedal assembly and replaced the Master and the Slave. Bleed with power bleeder and have driven the car, but the pedal continues to have to be pushed to the floor to get the clutch to release. Have full pedal travel as i have removed the bottom stop and still have same issue - Thanks for feed back. this has always been an issue since I first bought the car - guess I will take all apart again for another look.
to work, any hydraulic system need to balance the size of the master and slave against the other operational constraints, like travel and input/output forces.
This is most commonly run into when changing calipers in brake systems or when going from a twin inline master to a dual parallel setup.
Why did you need to go away from stock?
Feral - yes, tried the German slave, it is designed to ease pedal pressure but, requires a greater amount of hydro fluid to do so - so made condition worse.
Bill - no change except above which was reversed. My master and slave are OEM. I am wondering if issue is in the GT3 clutch set up I have. Because me disengagement point is so low (floor) I was just thinking that a larger master would move a greater.volume to the slave.
Yes, replaced rubber hose at slave - still feels like there is flex there and am going to replace with stainless .
At this point everything is new - bushings. Pin, master, slave and rubber hose. Pressure bleed, and have rebleed 4 times since. Contact rod to clutch arm has no play.
IHI KING!
Good luck with getting the issue resolved.
When Dan did mine they just replaced the clutch master, slave and hose w/ stock parts and an updated kinematic arm. The issue then was low engagement as you describe. The bearings on the clutch release arm had failed causing this. It needed a new clutch release arm, 997.116.086.90 The clutch disc 996.116.015.32, pp 964.116.028.03 and to bearing 944.116.080.01 were all replaced at the same time.
Thanks all for info and suggestions - am going back in to check all, if OK will pull trams to check arm and bearing. Will replace river hose with stainless line to see if this helps also.
