964 Forum 1989-1994
Teardown begins. Suspension madness...
Old 08-20-2016, 09:58 AM
  #916
Goughary
Goughary's Avatar
Yeah nick, the spacer I made was 15mm already. But there is an indent where it sits and then the bolt heads on the top hat come down a bit, so I need another 10mm....
And then there is the issue of the upper perch we are using, which is a stock 993 part. The springs sit metal on metal on the perch? But that's not a tight fit. Is this the way Porsche intended for the 993 perch? Or am I missing something? It's the first time I have tried to resolve this issue in this manner, and rennline as usual, has no idea, since they don't do any test fitment....
Old 08-20-2016, 10:39 AM
  #917
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
Can you post some more pictures of the assembled unit. Spring, perch, top mount, spacers, where it is rubbing, etc?
Old 08-20-2016, 11:29 AM
  #918
HalV
HalV's Avatar
Here's what PET has for the 993 rear (non RS).
It's hard for me to see from your picture if you have all the pieces located above the spring. In addition, if I look at the Rennline instructions, it looks like you might need the "optional" lower flat bushing.
Old 08-20-2016, 04:29 PM
  #919
Goughary
Goughary's Avatar
In the rennline instructions - see the one labeled "shock hat"- that's the 993 part they sold us to go w their monoball top hat. Rather than being conical or a "witches hat", it's flat. So it needs a bigger spacer than the one I made. I'll post pics if I get some while its apart. This would be significantly easier if we were dealing with 2.5 Id springs like on a standard coilover. But since we are mating an oem diameter spring to the monoball, it's just fiddly since no one just makes a kit that works...strange cuz you'd think rennline would just make it simpler...but then not many people make the jump to make this kind of upgrade without doing higher end and more adjustable setups...funny thing is - for road use, this setup is ideal. And a lot less expensive than moving up the ladder ....
Old 08-20-2016, 08:46 PM
  #920
Goughary
Goughary's Avatar
Had to re-bleed my car today...there was a ton of air in there...interestingly enough, the one thing I wanted to bleed the most was the clutch, and I completely forgot to bleed the clutch as I rushed through the brakes, pressure booster, PDAS solenoid, and the diff locks...but tomorrow am ill toss the bleeder on the car and whip that out...
So here's the deal. A couple years ago I went to pelican at the behest of my buddies here on rennlist and bought the be all end all of bleeders. The motive power bleeder with the super duper billet alluminum cap and all the goodies. Longer hose etc. but to bleed a c4 fully, I have to refill it a couple times while bleeding. And that's not only a pita, but everytime you glug glug glug a can of fluid into it, you introduce air into the brake fluid. And then you have to either wait for the bubbles to come to the surface of just be super careful adding the fluid.
Solution...go to motives website and buy a 1.5 gallon power bleeder. With a quick release so now I can swap my hose to the little one for c2 bleeding and to the big one for c4 bleeding . Add the right amount of fluid once and done...
Old 08-20-2016, 08:49 PM
  #921
Goughary
Goughary's Avatar
On the rear strut issue. I found these in my bag of tricks. Isolators from a 991...these will get rid of the spring noise and then I'll just make a larger spacer and we should be good in the hood...the spacer I made was 15mm. So I'll go 25mm and see how that goes. Should be just what the dr ordered...
Old 08-24-2016, 03:29 PM
  #922
Goughary
Goughary's Avatar
Finally on the ground- noise found. The monoball top hats were missing a spacer - the shop screwed up. No biggie...she's on the ground and ready for ride height to be set and alignment. Car 5 getting there...
Old 08-26-2016, 10:00 AM
  #923
Goughary
Goughary's Avatar
Off to butzigear for alignment this morning. Of the original group, this is the last car....very exciting stuff. Not done yet, but getting close. This alignment basically closes the suspension project and I move on to some details and finishing - like pop-out rear qtr Windows, etc...
Old 08-27-2016, 01:27 AM
  #924
Goughary
Goughary's Avatar
Alignement done. Car is beyond fantastic .
I set the ride height slightly high since the springs will settle. Alignment and ride height will be tweaked later...
Old 08-27-2016, 01:29 AM
  #925
Goughary
Goughary's Avatar
And then on to the seat motor. Front motor wasn't working so I rebuilt the seat switch
Size:  992.6 KBName:  photo651.jpg
Size:  973.0 KBName:  photo139.jpg
Size:  1.17 MBName:  photo192.jpg
Size:  939.7 KBName:  photo403.jpg
Size:  918.2 KBName:  photo613.jpg
Size:  1.03 MBName:  photo300.jpg
Size:  905.7 KBName:  photo743.jpg
But turned out the motor had been unplugged...lol...so all good now!
Old 08-27-2016, 01:32 AM
  #926
Goughary
Goughary's Avatar
The rennline pedal needed to be adjusted - I had set it like mine. But the pedal in a c2 is harder and higher than a c4...so the pedal needed to come back a bit toward the top and I took out the upper extension as I do with all of them. Now heal and toe is completely natural in this car...
Size:  929.3 KBName:  photo189.jpg
Size:  1,021.5 KBName:  photo816.jpg
Old 08-28-2016, 12:33 PM
  #927
Goughary
Goughary's Avatar
Respit from Porsche's and only spectating....but we won yesterday. Today, so far not so much...but it's a fun day at NJ Motorsports park anyway...
Size:  1.16 MBName:  photo742.jpg
Size:  866.2 KBName:  photo394.jpg
Size:  895.8 KBName:  photo912.jpg
Size:  1.13 MBName:  photo819.jpg
Old 09-05-2016, 02:19 PM
  #928
raffsracing
raffsracing's Avatar
Default suspension madness
Wow that was a very informative build thread. Wish i had found it before i started my project. Almost finished now.
Old 09-05-2016, 04:07 PM
  #929
Goughary
Goughary's Avatar
Wow that looks fantastic! Great job...
Now stick a dbfd sticker in your window and take the plunge! Just say "no" to garage queens! Lol...
Really great stuff. Would love to see more...
Reminds me - I've been travelling so much that I forgot to post the Windows... Here they come
Old 09-05-2016, 04:10 PM
  #930
Goughary
Goughary's Avatar
Terrible pictures sorry, but the rear qtr windows were sanded, primed and then shot with semi gloss black to match the oem trim...pics are of the primer stage.
These will get built and installed next week. And then I'll need to drill and mount the correct lower window trim and the pinch welt...and done!
Size:  1,008.6 KBName:  photo604.jpg
Size:  1.12 MBName:  photo368.jpg
Quick Reply: Teardown begins. Suspension madness...
