964 Forum 1989-1994
Teardown begins. Suspension madness...
Old 04-25-2016, 06:15 PM
  #691
HEDR
HEDR's Avatar
Default Intro to Aja and what comes next
First I'd like to thank Rob Goughary for what you are about to see. For making the suggestion that I didn't have to continue driving my car in the state she was in and challenging me to Make Awesome Happen.
Now meet Aja... (after the 1977 Steely Dan album.) Or whatever new name Dr. Rob comes up with. I'm sure this will be one of many posts over the next few weeks on Aja's progress. Here's how I found her.
92 C2
All of the changes I've made are all reversible...
Added this face
These are great for easy lifting
Low profile pucks help out.
Here's What Rob has asked me to add for a while... While dealing with a pair of used Recaro comfort seats I had to make a few parts out of Hot Glue... Yes even hot glue-gun glue can be made into almost any small Nylon part with some hard clay as a negative mold and patience. Here are the photos they're self explanatory.
Threaded motorized rail end bushing.
The cracked one. Essentially a flat washer with a hollow nipple and a 1/4 thick groove to hold it on the threaded rod end. On a Sunday there are no Recaro part stores open. So make one!
A little rough.. but it worked beautifully and the seat's threaded rod was solidly in place.
Last weekend. After hours of scraping "23 year old Gorilla Glue" out of the back of Aja's rear deck...
Before Rob sent me into the CAVE
and still going...
We are adding a little Dynamat or a thinner lighter version later to the rear firewall.
Here are some things to be careful of in any PPI
13 BALANCING HOLES?
All that missing magnesium was bound to crack
Thankfully I found these cracks before they became engine shrapnel.<br/>
I got her 3 years ago and have slowly made a few select reversible changes as you'll see.
MOMO for knee room prior to Rob moving seats back. Rennline floor boards for now with Aluminum Track mats going in after removing sound deadening.
Cant wait till POP OUT's are in & suspension madness resumes!
On my way to C&C in New Canaan last year. Merritt Parkway rest stop Southbound...
Old 04-25-2016, 07:02 PM
  #692
jpar
jpar's Avatar
Looking good Darren, good to see you're making progress.
Old 04-25-2016, 07:46 PM
  #693
JG 996T
JG 996T's Avatar
Awesome on the way!
Old 04-25-2016, 07:58 PM
  #694
HEDR
HEDR's Avatar
Thanks!
Old 04-25-2016, 08:30 PM
  #695
gavonder
gavonder's Avatar
Very cool. You're in good hands with Rob.
Old 04-28-2016, 02:04 AM
  #696
Goughary
Goughary's Avatar
So looks like we are heading out for upholstery and a new headliner on Monday. So it's crunch time. Glue on the rear deck has to go. And I have to glue/seal the drain tube in the sunroof that had separated. New seats are ready to go.
Today was the other rear quarter window. Cutting the slots, installing the Jack nuts and drilling and tapping the holes for the hinges. You have to be correct within 1mm when you cut the slots for the hinges. And there is no welding if you get it wrong. At least, not with my welder. Way too aggressive. So if anyone reading this makes the attempt...take your time and start cutting in the center between the two holes, and work your way out. Less likely to get in trouble...
This side was much easier. Only took a few hours really. Of course, the headliner is out and the area is apart. When I do mine, things will be very different as my headliner is not coming out. So not sure how easy that will be yet...
Size:  958.9 KBName:  photo874.jpg
Size:  889.3 KBName:  photo213.jpg
Size:  1.05 MBName:  photo54.jpg
Size:  1,020.7 KBName:  photo641.jpg
Size:  1.05 MBName:  photo53.jpg
Size:  1,017.0 KBName:  photo791.jpg
Size:  1.01 MBName:  photo323.jpg
Old 04-28-2016, 07:49 AM
  #697
gavonder
gavonder's Avatar
Was the flip out window an option on the 964, or is it from an earlier car?
Old 04-28-2016, 01:58 PM
  #698
spartansix
spartansix's Avatar
It's from an earlier car - even though popout windows were never available on the 964, the important parts are all the same size and with some cutting/drilling/tapping will fit!
Old 04-28-2016, 02:29 PM
  #699
JG 996T
JG 996T's Avatar
And the holes for the mounting bracket are still on the chassis!
Old 04-28-2016, 02:57 PM
  #700
Goughary
Goughary's Avatar
Kinda...this conversion is MUCH easier on the eighties cars...but the basics are still there and ready to go.
Trick is getting Windows. Porsche is out at the moment of oem black Windows, so you have to source older Windows and convert them. Porsche will do a production run at some pin ton the future. Although to my mind, they have an opportunity they are missing right now, since they are opening Porsche classic shops in the states and this would be a widely done conversion if they simply made it easy to get the work done.
Our issue on the 964, was that there was/is little to no information on how to do it to our cars. So we just had to start cutting and figure it out.
I hope the pics help. I know I've been less detailed lately in my posts. But I'm on the "way overwhelmed" side of life at the moment and don't have the hours to write that I used to have.
Old 04-29-2016, 07:32 AM
  #701
GeorgeK
GeorgeK's Avatar
Those pop-outs are a brilliant idea.
One thing to consider, though: I have had them on several cars, and to keep them water-tight is NOT easy. New seals and careful adjustment are very important.
Old 04-29-2016, 08:47 PM
  #702
Goughary
Goughary's Avatar
Old 04-30-2016, 08:45 PM
  #703
Goughary
Goughary's Avatar
these will likely print this week if anyone wants to jump in and order...
https://teespring.com/dbfd_awesome
make awesome happen
more to come - fyi - the front window does not have to come out to remove the dash cap - not sure why people keep telling me that. we did it today. pics later.
Old 04-30-2016, 11:33 PM
  #704
Goughary
Goughary's Avatar
Dash cap removal...
Size:  924.8 KBName:  photo348.jpg
Size:  914.6 KBName:  photo582.jpg
Size:  990.7 KBName:  photo189.jpg
Size:  1.01 MBName:  photo367.jpg
Size:  752.1 KBName:  photo680.jpg
Old 04-30-2016, 11:36 PM
  #705
Goughary
Goughary's Avatar
and then for swapping the antenna booster. It's on the far right hand under the window. You'll need some long 1/4 drive extensions and a deep well 10mm socket. Get ready to drop the nut. So a long magnet isn't a bad idea just in case.
Size:  900.4 KBName:  photo930.jpg
Size:  1.01 MBName:  photo146.jpg
Quick Reply: Teardown begins. Suspension madness...
