Help with heated seats.
Did a search came up with nothing. I am working on someones 964 and the heated seats aren't working.
I followed the procedure in the workshop manuals. Everything is working. Switch gets proper voltage still no heat. When I test for resistance on connector # 3 per the manual I am getting full continuity so no resistance which would explain why no heat is being generated.
I am assuming this means the coils in the seats are NG. Not sure how this could happen but am I heading in the correct direction. None of my 911's ever had heated seats so I am at a loss with this one.
I have heated Seats in mine as well, but never used them. Should try them out, does the engine have to be running for the seats to work??
My heated seats don't work either, I was guessing the element had burned out.
I find it strange nobody has any answers for this. I am sure it is a common problem.
These are just resistance coils so why would they loose resistance? If they burned out I would assume there would be no continuity but instead I have 100%.
Any electrical engineers around here?
I have functioning heated seats. I haven't checked to see if they are on without the motor running, but when the motor is stopped the seats get switched off, so when you restart the engine the seats have to be switched on again.
I would suspect the switch. It i went bad on my car. Expensive.
There is no mention of any resistor or anything so I am at my limit of trying to figure this out since it sounds as though they should be heating but they are not.
