964 Forum 1989-1994
Rs heat bypass, no fan power?
Old 08-25-2015, 10:33 PM
xcoldricex
xcoldricex's Avatar
Default Rs heat bypass, no fan power?
I read that the rs heat bypass doesn't really affect fan output. however when I installed mine I am getting very low fan output and turning the fan **** from 1-4 doesn't do anything. is this because I need to hook up the unplugged lines that went to the elbow that was replaced or do I have broken fans in the dash?
Old 08-25-2015, 10:36 PM
Vandit
Vandit's Avatar
If you set the CCU to max cold or max heat, do the fans work properly?
Old 08-25-2015, 11:27 PM
Vegas993
Vegas993's Avatar
You removed the rear blower motor, so yes, it does affect fan output. You need to remove a relay from the fuse box in the engine compartment and make jumper so you can control the fan speed of the secondary blower in the dash. The type of jumper depends on the year of the car.
https://rennlist.com/forums/964-foru...uestion-2.html
Old 08-26-2015, 09:02 AM
DobermanDad
DobermanDad's Avatar
When I did mine, the heat still blows. A little less, but I still get heat.
Did you do the relay mod?
Old 08-29-2015, 07:03 PM
xcoldricex
xcoldricex's Avatar
works now! removed the heater blower relay and did the mod as detailed in
https://rennlist.com/forums/964-foru...-solution.html
thanks DobermanDad. i have a 1990 and the wire was purple just for another data point
I don't really notice a difference in fan power without the heater blower fwiw.
Old 08-31-2015, 03:27 PM
DobermanDad
Mine was the same color as described in the DIY. 89 C4.
I also didn't notice much of a difference in fan power.
Old 08-31-2015, 07:01 PM
David A
David A's Avatar
You can get a dummy relay.
https://rennlist.com/forums/993-foru...pass-tube.html
Old 09-01-2015, 01:53 PM
xcoldricex
xcoldricex's Avatar
yeah I was wondering if that would work - I may do that to make it even easier to reverse
Old 09-01-2015, 01:55 PM
DobermanDad
That mod only works with newer 964s. 91 and up.
Old 09-01-2015, 04:10 PM
Vandit
Vandit's Avatar
My car is a mid-year '91 (plastic intake, circular latch) and I don't run a rear blower, I don't have any special jumper arrangement, and my interior fans operate like normal when my CCU is set to max cold.
My understanding is that the interior fans works like normal even w/o the rear blower as long as the CCU temp **** is set to Max Cold or Max Heat. Set it anywhere in the middle, and the CCU shuts them down because of the lack of the rear blower.
Old 09-01-2015, 04:17 PM
xcoldricex
xcoldricex's Avatar
mine only worked on max cold, not max heat without doing the wiring modification.
Old 09-01-2015, 04:38 PM
DobermanDad
Mine too.
Old 09-01-2015, 05:06 PM
FlyinTomato
FlyinTomato's Avatar
I just ordered that bridge adapter. Will report back if it works. I have a 92
Quick Reply: Rs heat bypass, no fan power?
