964 Forum 1989-1994
DIY - 993 coils into 964
Old 07-15-2015, 06:49 PM
tdiquattro
tdiquattro's Avatar
To be clear YOU DO NOT NEED THIS TOOL. just £30 worth of used coils and cables and a 6mm bolt.
Old 07-16-2015, 02:58 AM
Silvertarga
Silvertarga's Avatar
Dust covers (Protective cap) for coils is 993 602 801 00
Coil Plug is 928 602 557 00
New Bosch Coils from Rock Auto are about $125.00 plus shipping, Here is a 5% discount code
3201245729280789
No affiliation with Porsche NA/ Gmbh, Rock Auto or pretty much anything else!!
Old 07-16-2015, 04:13 AM
ThomasC2
ThomasC2's Avatar
How did you mount the bracket for the two wiring loom connectors since it's not in the same position as with the 964 coils? (Lying flat instead of vertical)
Old 07-16-2015, 06:00 AM
hepkat63
hepkat63's Avatar
anyone have a part number for the 993 HT leads please? finding hard to locate some (only to pinch the ends from them !!)
Old 07-16-2015, 06:26 AM
Silvertarga
The lead is 993.602.060.07
As noted above the ends are part 928 602 557 00
lfl215l (08-07-2022)
Old 07-16-2015, 10:53 AM
-nick
-nick's Avatar
I'm no EE, but you might want to compare specs between the coils before swapping them over. With too much dwell time they're not going to last very long.
Old 07-16-2015, 11:44 AM
tdiquattro
tdiquattro's Avatar
Just mounted them over the existing threaded stud, just add a plastic nut to hold in place, the heat sink is not altered and will do its job.
cheers
Old 07-16-2015, 11:26 PM
Silvertarga
-nick..point taken but it cant be any worse than the Silver Bosch coils!!
Old 08-03-2015, 07:32 PM
Duck
Duck's Avatar
Any update from those that have made the switch?
Old 08-04-2015, 05:17 AM
tdiquattro
tdiquattro's Avatar
All good, several hundred hard miles and perfect.
Old 08-04-2015, 06:39 AM
Duck
Duck's Avatar
Thanks for the update. I have this set up all ready once I get back my engine from shop.
Old 08-08-2015, 09:51 PM
Duck
Duck's Avatar
Has anyone had problems installing the 993 connectors 928 602 557 00? I bought brand new ones, but cannot seem to get them connected. I can reinstall the old end connectors easily, but the 993 just will not spin on.
Old 08-09-2015, 12:51 AM
Silvertarga
New connectors are a tight fit, try spraying some silicone on them to lube or get the new connectors warm so the rubber is flexible
Old 08-09-2015, 07:50 AM
Duck
Duck's Avatar
Might try warm them up a little. Already tried the silicone, but cannot get them to connect. Very easy with the 964 plugs.
Old 08-09-2015, 08:44 AM
Duck
Duck's Avatar
Got one connected. Will try the other one later. Hope it works well. Definitely like how the coils fit and will be nice to no longer use those silver coils.
Quick Reply: DIY - 993 coils into 964
