964 Forum 1989-1994
Lower motor mount nut removal
Old 07-01-2015, 11:48 AM
Streetdaddy
Streetdaddy's Avatar
Default Lower motor mount nut removal
Over at a friends house to replace mm. Trying to figure out best way to access lower 19mm nut. Need jack stands? Any help would be appreciated!
Old 07-01-2015, 11:51 AM
DobermanDad
DobermanDad's Avatar
Should be a hole right under the nut to fit a socket with an extension onto the nut.
Old 07-01-2015, 11:57 AM
Streetdaddy
Got it . Thx!
Old 07-01-2015, 12:07 PM
crg53
crg53's Avatar
I know this is obvious, but please do not forget to support the engine. Another issue, if you have a hard time with the nuts, I.e. They won't come loose and a lot of force is needed, there is a VERY good chance you will twist the engine carrier bosses. If that happens, you will need to take the carrier out and straighten them, and at that point you may as well weld in the Rennline bracket. Talking about a slippery slope. :-))
Old 07-01-2015, 01:17 PM
Streetdaddy
For all the help and tips guys CRG probably glad I didn't see yours before I tried it I would've been scared… They went in without a hitch and first drive was awesome!
Old 07-01-2015, 01:22 PM
DobermanDad
Mine came off easily too. Thought is was gonna be really hard to get them off. Nope, came right out.
What mounts did you get?
Old 07-01-2015, 03:40 PM
Goughary
Goughary's Avatar
Don't know if you already have a reinforced engine carrier, but if you don't, it's not a good idea to install stiff mounts, ie wevo or other without doing that. Rennline has the best one.
Old 07-01-2015, 03:42 PM
Streetdaddy
I bought the 993 mounts. Mine is a street driver, didn't want it too stiff!
So much oil/dirt i couldn't see the pop out discs.
Old 07-02-2015, 04:52 PM
RicardoD
RicardoD's Avatar
You may need a very deep socket, I believe 19mm, as the bolt on the 993 mount is much longer than the stock 964 mount. I bought a special very deep socket when I installed the 993 mounts on my C2.
Old 07-04-2015, 10:19 PM
Goughary
Goughary's Avatar
Ricardo...link?
Or will we see it in your engine build thread on the re-instal????
Quick Reply: Lower motor mount nut removal
