964 Forum 1989-1994
Recharging the AC system
Old 06-04-2015, 03:17 AM
Netbug
Netbug's Avatar
Default Recharging the AC system
So my AC system isn't working because I need a recharge. I found some R12 cans and wanted to know if I should get it charge with this, or retrofit to r134?
If the R134 just as efficient?
Old 06-04-2015, 07:03 AM
newsboy
newsboy's Avatar
If you have the R-12, use it. Some cost to retrofitting to 134, and I don't believe the cooling is as good, although others may disagree.
Old 06-04-2015, 08:34 AM
griffiths
griffiths's Avatar
Are you going to fix the leaks first, then evacuate the system and charge it?
Old 06-05-2015, 04:03 AM
Netbug
Netbug's Avatar
Yes I will have the system checked for leaks and the evacuation and the charging completed. But I have also seen that it is difficult to put r12 into the vehicle since nobody carries the equipment now.
Old 06-05-2015, 09:33 AM
bobaines
bobaines's Avatar
If you can fix the system and eliminate all leaks keeping R12 is your best path. If you switch to 134 you will need to replace all lines to barrier lines in addition to valve change. It might be hard to find people willing to work on an R12 system in Cali, which would tend to drive you to switch.
Old 06-05-2015, 12:05 PM
Earlydays
Earlydays's Avatar
Changing the barrier lines is "optional"......yes, R134 may "leak" due to it's different molecular structure in original barrier lines, but it is something you can wait and see and then address as necessary. Probably always cheaper to top up with R134 anyway.
My system is working well after a conversion a year ago and I did not change the barrier lines.
Old 06-05-2015, 11:11 PM
Turbohead
Turbohead's Avatar
I have some R12
PM me if you want it
Elliot
Old 06-06-2015, 03:32 PM
wwest
wwest's Avatar
Initially there was a "requirement" that when converting to R-134a you should switch to barrier hoses (R-134a, smaller molecules, blah, blah, blah, etc ), but later laboratory testing indicated that non-barrier hoses "pre-conditioned" through the use of R-12 and R-12 lubricant did not leak at a significant level.
According to the EPA and DuPont statements available on the internet.
In addition, some manufacturers still use non-barrier hoses on the suction, low pressure side of the system, a clear indication that system operating (excessive ?) pressure plays a significant part in the question of leakage or no.
Which is why the EPA REQUIRES that a pressure switch be added to legacy systems such as ours during an upgrade to R-134a. Many older systems, of our era, up to the early 90's, incorporated an ~500 PSI HPRV, High Pressure Relief Valve, to vent excessive high side system refrigerant pressures to atmosphere.
Vent R-12 to atmosphere..?? Yes, that is correct, R-12 was then relatively inexpensive and was no yet known to be adverse to our atmosphere.
But our systems have no HPRV...
Did Porsche consider non-barrier hose permeation under excessive pressure to be the solution?
Our system's, under certain specific circumstances, are theoretically subject to excessive high side system pressures....
With the evaporator iced over, for instance, not exactly an uncommon situation. Our thermostatic control switches, at maximum cooling, full CW, open the compressor circuit only once the sensor detects a temperature slightly below freezing. Some switches might be so far out of calibration that the compressor clutch "off" action is well below freezing.
ICE is a GOOD insulator, once the evaporator is mostly frozen over the sensor will/might be insulated against temperatures below 32dF.
Then the compressor runs continuously until you discover the freeze-up condition, lack of system airflow, and manually switch the system off long enough to defrost, DE-ICE, the evaporator.
What high side pressures might you then see at 3000 RPM.
Most qualified A/C shops will convert your system to R-134a for about $200. That does not include an R/D upgrade nor a pressure switch installation/wiring. $300 will get you both of those, <$30 for the R/D, and <$20 for a pressure switch with R-134a adapter.
http://www.carid.com/1989-porsche-91...FYdbfgodPa0APQ
http://nostalgicac.com/oil-switches/...port-7-16.html
Old 06-06-2015, 04:10 PM
wwest
wwest's Avatar
My R-134 conversion is now entering the third year, 1988 Carrera, factory hoses throughout.
But it does have a Red Dot 71R7500 pressure switch, 325 PSI compressor clutch cutout. Lots of R-134a pressure switches in the market, Griffiths, etc, have a high pressure cutout of >400 PSI. Probably fine with barrier hoses, but seems a bit high for our non-barrier hoses given the Red Dot option is available.
Amazon.com: Red Dot Trinary Pressure Switch - Generation II 71R7500: Automotive Amazon.com: Red Dot Trinary Pressure Switch - Generation II 71R7500: Automotive
Old 06-07-2015, 01:14 PM
creaturecat
creaturecat's Avatar
interesting, wwest.
could you advise me re: how to install the red dot pressure switch?
Old 06-07-2015, 01:25 PM
griffiths
griffiths's Avatar
Interesting Mr. West. However Griffiths does not have a high pressure cut out switch >400 psi.
Mr. West, you see to have an obsession with either bad mouthing Griffiths products, or leading the forum members astray with your comedy.
Are you looking for a time-out in this venue as well?
Old 06-07-2015, 05:39 PM
jimq
Burgled
jimq's Avatar
you must be one of those secret mods I have always heard about on RL for the last 12 years
Old 06-07-2015, 05:55 PM
Vandit
Vandit's Avatar
I've never heard of having to replace/update the pressure switch on a 964 due to a refrigerant switch.
The 964 pressure switch resides in tight confines on the top of the HVAC suitcase, between servos and stuff. I'm not sure any switch is just gonna fit in there unless it is a thin design like the stock piece.
You can see it in this pic.
Old 06-07-2015, 08:06 PM
Mr.Alex
Mr.Alex's Avatar
As sad as it may sound, I've never done anything AC related. Is there a thread or good youtube video that might help me recharge mine on my own?
Old 06-08-2015, 12:56 PM
wwest
wwest's Avatar
Well, at least we have now narrowed down a Griffiths "trade secret" that far.....
Quick Reply: Recharging the AC system
