964 Forum 1989-1994
Need help with alternator spacer ASAP
Old 05-26-2015, 06:17 PM
DobermanDad
DobermanDad's Avatar
Default Need help with alternator spacer ASAP
I'm reassembling my alternator back to the dual pulley and noticed I'm missing a part. It's the spacer that fits between the hub and the alternator on the shaft.
Does anyone know the length it needs to be? I can get the ID from the bearing on the hub with a micrometer, but I don't know the length.
I'd really appreciate any info you have. I'm going to make a billet one on a lathe, so I can drive my car again. Hoping to not have to order one and be stuck waiting again.
Something is missing:
Could it be this (top left)?
another:
Old 05-26-2015, 08:04 PM
DobermanDad
20mm length?
17mm ID
Old 05-26-2015, 09:24 PM
mojorizing
mojorizing's Avatar
Here's some dialog on that spacer
https://rennlist.com/forums/964-foru...lternator.html
Old 05-26-2015, 09:39 PM
DobermanDad
Originally Posted by mojorizing
That's perfect! Thank you
Old 05-27-2015, 10:27 AM
DobermanDad
In case anyone needs to know
Length 24mm
ID 17mm
OD 30mm
Old 05-30-2015, 11:26 PM
DobermanDad
Made this out of High grade aluminum.
Quick Reply: Need help with alternator spacer ASAP
