964 C4 1989 with 1992 engine - clutch question
All,
Currently experiencing a slight vibration in my clutch pedal when shifting gears. Clutch is replaced 50.000km ago. Shifting goes well, but I'm expecting something is wrong. My c4 is a k-series (1989) with 1992 engine.
K-series use a different clutch than later models. Does a 1992 engine effect the type of clutch that needs to be installed?
1989 models have Single Mass Flywheel. I expect the replacement of the engine does not involve an 'upgrade' to a dual mass flywheel. Is my assumption correct?
Thanks in advance!
Thanks in advance!
