Oil Pressure Sender?
Last two-three drives out I've noticed the oil pressure needle dipping a bit lower than usual than usual. Upon cold start the pressure is about 3.5-4 bars, and as it warms up my pressure was usually somewhere like 1.5bar or a tick above 1bar. But recently as it gets around 8-9oclock temp, the pressure started ticking a notch below 1bar as idle hunts a bit. I have no oil pressure warning light however, and via dip stick my oil level is around 3/4. Oil is BP 20/50. The only time I had the oil warning light come on was around a year ago when I was hooning on a particularly warm night, but never again.
Should I be concerned? Is there any way to test the sender without having to remove it? I see its behind the intake stacks, and I've never removed those before.
I would be concerned. I'm surprised that your oil light is not coming on with that low of oil pressure reading. When I had a flaky Oil Pressure sender and the car was hunting for idle the gauge would bounce around erratically near 1.5 bar. Sometimes the gauge would bounce under 1 bar the oil light would come on.
just had mine replaced on my 91 c4 after the car just randomly started dip in to sub 1 bar at idle after about 10 minutes of driving one day. I'd get the oil pressure light on and then when i'd start driving the light would go off but would always come back down to low pressure at a stop light.
when i started searching online i freaked out as i was finding people saying that it's either the oil pressure sender or some kind of tragic engine issue that requires a rebuild. the next day i took it to brian at the stable in San Francisco and they swapped out the oil pressure sender and all was right with the world.
just my experience. it's an easy swap so i'd start there.
keep us posted
B
keep us posted
B
Ok hold on. My oil pressure gauge has always read low like that at idle. And then pegs itself on the high end as soon as I am no longer idling. I thought and was told this is totally normal.
Can someone tell me exactly how this is supposed to function? Maybe Alex's problem isn't a problem, or maybe mine, which seems similar to his, is a problem?
In my experience which includes 2 different senders (one went bad) on the same car, and two different senders on another car (both cars were 92 and 93 964s), they all operate ever so slightly different (provided they are not defective). As long as the oil light does not come on at hot idle, and the gauge pins at 5 bar when at 4k or higher RPM, you are fine.
The car runs 100% though, will hit 5bar when getting on it.
Is the pressure sender responsible for the warning light coming on as well, or is that a separate circuit sensor?
Went through some logs of the service records, looks like the sender was replaced in 2011 with an FAE Brand Sender ~32$. I've read in a one or two other threads that a good sender will shoot to the top with the ignition on, and then lower itself once you fire up the engine. Can anyone confirm this for me with your cars? Currently mine just moves a tiny bit above zero with the ignition on.
Mine behaves like yours does, I've earthed mine today to check the gauge isn't sticking as I can't get higher than 4.5 bar, earring it out will cause the gauge to read full pressure. I then put a manual pressure gauge on the car and when my car says 3.5 it actually measures 6! The lesson here is don't trust the gauge as they're crap. My sender was brand new as well, should have left the old one on. My advice is take your car to a garage. If you read your manual it says your car is fine
Sounds good. Idle will vary from car to car, even among rebuilds.
Your oil temp seems a bit high, that would account for the lower pressure at idle. Have you checked your oil cooler and fan for proper operation. You may just have a dirty oil cooler, if it's never been cleaned, I would start there first.
THIS will give you an idea, what a dirty oil cooler look like.
I fitted a genuine one, not sure what I'll get next. I've been told that no two senders will behave exactly the same so my advice is get it to your local shop and have them put a manual gauge on it, it only takes 10 mins with a cool motor and will give you the piece of mind you are looking for. Had my car back for a couple of months and haven't dared drive it properly as my gauge wouldn't read above 4 after a full rebuild. Just got back from its first thorough thrashing and can't stop grinning!
