Which shocks for 1994 Turbo Look?
Hi all,
Which shocks to get for my 964 Turbo Look?
I upgraded a 993 with Bilstein HD's some time ago and the ride improvement was enormous!
Thanks. Q
Thanks. Q
Very much depends what you are using the car for. If street only, I would go with Bilstein HD and H&R Green (or whatever color they are now) springs. If you spend a lot of time on track, then the PSS 10 would be a good setup.
If you want an improvement in handling you want the reds which are slightly stiffer than what you have stock the greens will be softer than stock but the progressive rate and damping of the bilsteins will be an improvement.
