964 Forum 1989-1994
My 911design 1 of 1 "a proper 964"
Old 04-30-2015, 06:15 PM
  #31
Captain Ahab Jr.
Captain Ahab Jr.'s Avatar
as well as the obvious mods I love all the subtle changes that you have done, they all work together to make a great looking car, beautiful !
Old 04-30-2015, 11:26 PM
  #32
wilber
wilber's Avatar
My new tail lights!!!
Hope you guys like it.
I wanna give it a old school look!
Old 04-30-2015, 11:58 PM
  #33
StephenJ
StephenJ's Avatar
Could you post more pics of the interior? Did you go with RS carpets in the rear, integrated half cage? Absolutely love the look of it. Gives me something to aspire to with my stock-ish 964.
Old 05-01-2015, 01:41 AM
  #34
wilber
wilber's Avatar
Old 05-01-2015, 01:49 AM
  #35
niche
niche's Avatar
Finally, a proper 964. Congratulations!
Old 05-06-2015, 08:25 PM
  #36
wilber
wilber's Avatar
Old 05-06-2015, 10:04 PM
  #37
Big Al HURT123
Big Al HURT123's Avatar
I'm about to embark on a similar project. Would you mind sharing which coilovers, wheel size, offset and tires sizes your used. Those are the first things I'm going to do.
Thanks.
Old 05-06-2015, 10:47 PM
  #38
wilber
wilber's Avatar
Thanks.
Hi
I using JRZ Pro coilovers with ERP monoball and my wheel size is
18x8.5 et50 18x10.5 et53
225/40/18 285/30/18
Old 05-07-2015, 09:52 AM
  #39
911Jetta
911Jetta's Avatar
Great idea to surround the lights with trim. Works really well and would love to see more detail. What is the trim material?
The "Ruf" integrated-cage design is just stunning.
Old 05-07-2015, 11:01 AM
  #40
breljohn
breljohn's Avatar
I think there should always be a seal around the tails...
Old 05-08-2015, 01:41 PM
  #41
911Jetta
911Jetta's Avatar
Look at the pic again, there's extra trim on the exterior of the lights (if what I'm seeing is correct).
Also, Wilber's mention of, "My new tail lights!!! Hope you guys like it. I wanna give it a old school look!"
Are the lights taped off? Or is that trim?
Just curious as I played around with a similar idea before I decided to vinyl wrap the whole light.
Old 05-08-2015, 01:49 PM
  #42
FlyinTomato
FlyinTomato's Avatar
Hi
18x8.5 et50 18x10.5 et47
225/40/18 285/30/18
thanks for these info. Do you have rubbing issue with the front?
I have exact same wheel size and offset. running 235 tires. it rubs on certain steering angle(where most fun is) under compression. I wonder if it helps with dialing the caster back a little and running 225 tires.
Old 05-08-2015, 08:41 PM
  #43
wilber
wilber's Avatar
no robbing with 225/40/18
Old 06-03-2015, 07:04 AM
  #44
young_dennis
young_dennis's Avatar
Are any spacers used to get to the required offset or are the wheels 50 and 47 from factory
Old 06-03-2015, 11:22 AM
  #45
wilber
wilber's Avatar
i use 7mm spacer in the rear.
my new set up is 18x10.5 et53
techart wheel is et60 and add 7mm spacer to et53
Quick Reply: My 911design 1 of 1 "a proper 964"
