Tool Kits and air compressor
Does anyone have photo's of the correct tool kit and compressor for a 92
964? I am trying to put together for a newly purchased car.
Also any ideas of what was available in advertising for this year?
IHI KING!
The RS America.net website has some good photos of the 964 tool kit and all of the details.
http://www.rsamerica.net/oeminfo/toolkit/index.htm
As for the tire compressor, my 1991 has one similar to this
Photo from Pelican
Photo from Pelican
Photo from Pelican
Photo from Pelican
http://www.rsamerica.net/OEMinfo/air_pump/index.htm
Original toolkit roll and contents as per page 1 of the katalog. Most of the original tools (they wern't actually that high quality) typically lost or replaced with later, better tools of the same - which maybe isn't a bad idea. Many of my original tools I've moved to their own draw in the toolchest.
As a side note, my PO cut off the cig socket plug and installed mini banana clips to go directly onto the battery. Prob will make my life easier if I ever have to use it but was very surprised to see! Was this common back in the day?
I have seen people do it but if you need your compressor that often you might consider buying one that works. These are fine for an emergency but take forever to fill a tire. Harbor freight has one that will fill a tire in a third the time for under $15 on special.
Cobalt, Can you like that compressor from harbor freight. Can't find nit on their site. Thanks!
http://www.harborfreight.com/air-too...sor-61788.html
I sure could have used that pump for my spare yesterday. Had my first flat in the 964. I found the jack okay but no tool kit or pump for the spare. Where exactly in the frunk are they supposed to be located? I can't believe I could have missed them.
Wheel jack is stored in the recess behind the front bumper in the frunk. The tool roll is typically tucked away inside the space saver wheel or lying around in the trunk (like mine).
The 996 space saver has/had a foam moulded insert made to hold the jack and jack brace. Looks pretty neat. Part # 996 722 101 00. Not sure if this was an option or standard.
Agreed, I don't trust the OEM compressor and I have one of these as an emergency kit. You can get the 20oz bottles pretty cheap and refill them at any paintball supply shop.
