964 Ashtray ...
i think you can adjust the degree to which the front piece (dash like) is set with 2 screws
but it maybe your spring/tentioner is not correctly positioned
https://rennlist.com/forums/964-foru...ay-closed.html
Easy fix if same problem as mine. Small plastic piece to the right must be held tight against the tray so that the rounded end fits in a slot when the tray is pushed back in. I'm away from my car otherwise I would post a pic.
