964 Forum 1989-1994
Template for Early 964 Golden Rod/Short Shift Install FREE
Old 04-22-2015, 10:00 PM
Silvertarga
Silvertarga's Avatar
Default Template for Early 964 Golden Rod/Short Shift Install FREE
A year ago SuperUser was kind enough to send me the template that Rothsport made for him in order to install the goldenrod/short shift in the early 964 car.(you have to cut an oval into the tunnel) I am finally getting this project finished and if anyone wants the template I will send it on Free of charge, just as was done for me
All i need to do is get under there and figure out where to cut and I will send the template on to the next person so long as they will do the same for the next guy..
Here is a link to Daryls thread which shows the template
https://rennlist.com/forums/964-foru...-going-on.html
Old 04-22-2015, 10:18 PM
Mr.Alex
Mr.Alex's Avatar
I would probably be next on the list if possible. Bit to scared to dig in as is, but a laser cut template might give me the confidence I need to get it done.
Old 04-22-2015, 10:41 PM
hockenheimr
hockenheimr's Avatar
I want in too....I plan to order one in a few weeks but install only in the late summer. I'm pretty quick at getting things done so I will only have it for a few days and can pass it on right away if needed.
This is what Rennelist is about!
Old 04-22-2015, 11:15 PM
crg53
crg53's Avatar
I did this a few years back, and wrote this tread if you are interested. No need for a template, just a few tools and comment sense.
https://rennlist.com/forums/964-foru...t-install.html
Old 04-23-2015, 08:56 AM
SuperUser
SuperUser's Avatar
This is a great write up and I tried it first but had a hard time cutting the hole. With the template I just paint penned the shape and used a hacksaw and dremel tool to make the hole. The Golden Rod is a big improvement so whatever method you choose to make it work on your early 964 its worth the effort.
Thanks again to the guys at Rothsport from making the template and amazing shifter.
happy cutting
Old 04-23-2015, 02:46 PM
Silvertarga
I just have to figure out how the get the car up higher...this is no job for someone with no lift and claustrophobia!!
Once its done the template is on its way to Mr Alex and I would suggest to him that hockenheimr get it when he is done
Old 04-23-2015, 04:00 PM
Streetdaddy
Streetdaddy's Avatar
C2 only?
Old 04-25-2015, 06:54 PM
Silvertarga
Streetdaddy AFAIK the short shift is for C2 only, I think the goldenrod is also good for the C4, check FD Motorsports website (No affiliation)
Old 04-26-2015, 06:57 AM
davidwilson11
davidwilson11's Avatar
Originally Posted by Streetdaddy
C2 only?
Street daddy, if you find out post the results up. I would like one for my c4
Old 04-30-2015, 10:31 PM
Silvertarga
Job done and am quite pleased with the Goldenrod and short shift kit..I dont know how superuser did this with a dremel and hacksaw. I had a die grinder, nibbler and it took some doing (was easier to put car up on its side and come in from drivers side
For those of you who have not checked the cup socket fitting (or secured it with zip tie) Here is what happened when I removed the boot, the rod simply fell off, the boot was the only thing holding it on (the little white pieces on the ground are the socket liner, fell out of the boot!
Daryl Thanks again for the template..made things much easier and Mr Alex..its on its way to you
Old 05-01-2015, 07:57 AM
Streetdaddy
Says " fits all 964 models".....( except awd) 😂
Old 05-01-2015, 03:28 PM
Mr.Alex
Mr.Alex's Avatar
Thanks! Now I just have to figure out where to do this, maybe rent lift at friends place.
Old 04-03-2016, 09:25 PM
Mr.Alex
Mr.Alex's Avatar
Forgot I still had this! Whoever needs it just PM me your address. It was kind of dinged by the hole saw but still good.
Quick Reply: Template for Early 964 Golden Rod/Short Shift Install FREE
