Has the day come when a 964 is worth more than a 993?
#256
I was reviewing North American production numbers for non-turbo models and was surprised to see that there were as many Carrera 3.2 cars sold/produced as the 964 and 993 combined!
#257
Had a good laugh reading the 'Jalopnik' story....
(btw I am 74 and drive a 964 C2)...
Its all about collectors craziness....in 2001 I sold my Rolex Milgauss 6541 for 80K, which was unbelievable because the watch costed 800 USD in 1960....just now they sold one at Sothebys for 250k. WTF is going on ?
#258
Bug Lights rule !
That being said 1st 100k and I will walk as I will be scared to drive it and no longer be anle to afford
the insurance. It is kind of nice to have a car that is 25 years old and needs nothing. I wonder if the 997's will last that long and still be as solid ?
So then why have they completely stalled and have if anything seen a complete stagnation in value while the 964 is on a steady rise? I find most talk about air cooled 911's seem to omit the 993 from the conversation due to its change in looks. The 964 is the last of the original lines of the 911 and the last of the true sports car feel the 993 is so much more of a GT car than the 964.
#259
"I find most talk about air cooled 911's seem to omit the 993 from the conversation". I am not sure what conversations you are referring to...
#260
"The 964 is the last of the original lines of the 911 and the last of the true sports car feel the 993 is so much more of a GT car than the 964."
#262
When looking at the Coupes in the U.S., seems the numbers get interesting, especially when this doesn't delineate the C4's versus C2's and the Tips versus Manual. Looks like C2 Coupes with manual transmission in the U.S. has lower numbers than one might first imagine.
#264
AFAIK the only two numbers correct here for US market are the 1 America GS and the 20 1992 turbo S cars. For US production it should read closer to these for the NB coupes only this is US spec so all cars sold to Canada and surrounding countries buying US spec cars came from these:
1989 C4.............1057 units
1990 C2/C4 all....1257
1991 C2/C4 all....686
1992 C2/C4 all....655
1993 C2/C4 all....460
1994 C2..............130+/- The number he gives includes the widebody C4 but you need to get the exact numbers from the turbo Look registry to get it correct. IIRC he stated some 267 or close were produced for the US.
I went over this with Adrian back in the day and he amended his book and still had it wrong. He did a great job with what he had to work with but so much more has been learned since. All US MY vin numbers begin with xxx61 and not xxxx1 as he states. These numbers also have a fair number of double counted M718 coded cars that will bring it down even further but to figure that out will take a lot of research so these will do for comparison. I am using these numbers to show how many less were made than he stated but the number is actually less than what I posted.
This also applies to the remaining Coupes and targas and the turbos which are considerably less than he had noted (ie there were only 350 US spec turbo 3.6's imported in stock form vs the 466 he has noted)
Total narrow body production minus the RSA including all narrow body C2/C4 both manual and tiptronic transmission is only 4245 units vs the 6306 Adrian had listed. A fair guess is about half were C2 the other half C4's brings it down closer to 2000 of each now subtract how many tips were made of each it leaves very few if you are looking for a C2 or C4 coupe. Now consider how many were tracked, totalled, scrapped for parts, Singer and RWB builds etc etc. This leaves very few 964's in the US. No doubt there are a considerable amount made for the ROW market it doesn't do us much good here in the US. If you want the more desireable 92-94 MY That leaves less than roughly 600 of each including tips and by now there are very few still around I know of a bunch of 93's and 94 C2's that were totalled at the track. When you think of it the numbers are not far off the RSA for total production of 92-94 C2's and there are probably less left than of the RSA's
When you look at these numbers there were more 993 cabs and nearly as many 993TT's made as were 964 C2's in total. The 964 is no doubt the rarest of the US spec air cooled LWB cars
#265
Off topic.. I've always wondered how different a 92-94 is than my 90.. Especially given all the updates I've done to the suspension and transmission.
Can a 89-91 be made into a 92+?
#266
There are a lot of things you can upgrade but it is not necessary and the things that make a bigger impact have either been updated to most by now or cannot be changed. It shouldn't make a difference they were all good cars but they just fixed a lot of little issues with the later cars, most wouldn't even know that changes were made until I point them out.
The whole late MY production vs early became a thing years ago. IMO it is as much of a difference between a C2 vs an RSA and shouldn't matter but does to some.
#269
Most of the threads here and on other forums. The 993 has always been apart from the others de to its change from the standard looks. These numbers are so far off it is ridiculous and there is a huge difference between US and ROW production. In the US we primarily focus on the US spec cars which also include distribution to Canada and other surrounding countries.
Can you confirm your ROW and USA 964 numbers with specific citations ... many conflicting claims here.
#270
In every case if I punched in a vin below xxx61 it showed up as not valid along with any vins above what numbers Adrian had listed as the final vin number. I verified my cars and all options came up as correct so I have no doubt that the info was authentic. This is also verified by the 928 registry which has all vin numbers of every 928 imported to the US and not a single 928 MY has a vin between xxxx1 and xxx61. Apparently the first 60 vin numbers for US spec cars are required to be tested as test mules for each MY model with a specific vin number. Whether they actually tested these cars or just skipped over the numbers is yet to be determined.
There are also a number of M718 coded cars that are not documented but in every case that Adrian was not aware of it was double counted as he had initially done with the US spec 94 turbo 3.6.
I have been doing research on this for over 10 years and there are number of threads that will corroborate what I stated as true. If you can find any 964 with a vin between xxxx1 and xxx61 I would be interested in seeing it but I am sure they do not exist.
Also don't forget the numbers I posted include some of the rare cars like the America roadster for 1992 the 1 off America GS the Carrera Cup cars and Turbo S2 as these are part of the standard vin numbers and should be counted and subtracted from the totals. So as I said the numbers I posted are not even correct and should be less in total. We need to have a published chart that is accurate there has been a lot of false info being spread around for a long time.
