Urgent HELP decoding options codes 964 T
Hi,
I need urgent help to decode the option codes of this 964 turbo ( 1992 ) specially the code x33.
Is it a normal code x33?
And option 09991 ?
I will appreciate help,
And option 09991 ?
Hello,
I'm not sure for the 5 digit code (they're usually option packs), but the X33 was a power kit for 261kw - see this thread for more info:
https://rennlist.com/forums/964-turb...power-kit.html
and this:
https://www.stuttcars.com/technical/option-codes/964/
and this:
Probably a car made for California, but I guess that's no guarantee it actually ended up there. An easy way to see if it's a US car is if it doesn't have the side indicator repeaters in the front wings, it's from the US. I think the California cars also had some method of retrieving the fault codes by using the break pedal or something similar. Maybe someone from Cali will confirm this?
