964 Forum 1989-1994
Your O2 sensor history
Old 02-26-2015, 01:52 PM
C4inLA
C4inLA's Avatar
Default Your O2 sensor history
Curious as to history of mileage vs vehicle age and reasons peeps changed their exhaust O2 sensors.... I am still running on original ....
My history
94 C4 - 44k clock
Old 02-26-2015, 02:09 PM
Earlydays
Earlydays's Avatar
Original on my '90 C2...it has 101,000 miles.
Old 02-26-2015, 02:54 PM
ThomasC2
ThomasC2's Avatar
Mine is probably original at 180.000 km. But I have a new on the shelf for this season just because. No problems with the one I have.
Thomas
Old 02-26-2015, 04:47 PM
justin-in-athens
justin-in-athens's Avatar
Replaced due to non op at 165k miles. The car had been fitted with a test pipe at some point, so the heat shield was not there to protect it from direct engine heat--I imagine this is what killed it.
Old 02-26-2015, 06:53 PM
wachen
wachen's Avatar
Based on the service records that came with the car, the O2 sensor was replaced at ~75k miles.
The car is at 123K miles now.
Old 02-27-2015, 12:23 AM
C4inLA
C4inLA's Avatar
Interesting and quite good news on both parameters...
Old 02-27-2015, 04:03 AM
C24FUN
C24FUN's Avatar
Original on my 90 C2 with 115k miles.
Old 02-27-2015, 08:54 AM
elbeee964
elbeee964's Avatar
Changed, for '93 change's sake in '10, at 118k miles.
(Fuel injectors were sent out for refurb, spark plug lines and pressure sensor o-ring being replaced -- you get the idea.)
The old one was still working fine (no mpg bump noted), so it was relegated to a garage shelf.
Old 02-27-2015, 09:09 AM
ras62
ras62's Avatar
Replaced at 95k miles due to hunting at idle and intermittent hesitation at low revs. These things have some peculiar failure modes.
Old 02-27-2015, 09:12 AM
Vandit
Vandit's Avatar
Replaced mine a year or two ago at around 100k miles during a major-ish service including plugs, wires, caps, rotors, coils, cylinder head temp sensor, injectors serviced, new rubber bits, etc.
I was trying to solve an intermittent hesitation that progressed to an undriveable car. It went away. Luckily.
Old 02-27-2015, 12:51 PM
Mixter
Mixter's Avatar
Original O2 sensor.... 90 C4 - 62k miles.
Old 02-27-2015, 01:17 PM
boxsey911
boxsey911's Avatar
Changed mine as a precaution at 150,000 miles. Nothing to really say it needed it but I thought it deserved one!
Old 02-27-2015, 10:31 PM
Turbohead
Turbohead's Avatar
if it ain't broke .............you know!
Elliot
Old 02-27-2015, 10:38 PM
onceover
onceover's Avatar
Changed at 90k because it was stuck in my cat when I put a cat delete in.
Old 02-28-2015, 03:43 AM
964Lovac
964Lovac's Avatar
same here around 88k or so...
Quick Reply: Your O2 sensor history
