Need to know if enough interest in Singer style shift knobs
#31
Here is the mock setup i did with the Dansk. It would be same the same size, look,but with a better feel. I have no interest financially, just want a great ****. Not feasible for them to make just one **** for me. I think there is a demand, but need to see if i'm right. Anyone else want one of these?
Please excuse the ratty carpet, i am trying to find a pesky water leak. The paper towel is just a stand in for the bottom of a shift boot i will cut and fold under.
#32
In theory; if we just got the **** without the shaft or anything. I could use it with just the 928motorsports adapter and a different boot like the rennline ****?
In terms of shaft, something like this would be possible if the mounting for it was thought out.
http://www.grandbrass.com/images/pibr1-4pl.jpg
#35
#38
#39
Those look great. Another good option if you don't want black. I personally am going for the Singer look. But either way i think we can make it work.
Yesterday I went to a metal fabricator with my 10 cc syringe. I said i needed it a hair bigger. He pulled out an electronic measuring device. He then took me into the back. Man, i wish i had my cellphone. More pipes/metal than i have ever seen. He pulls out a stainless steel tube and says "this is your lucky day!"
I then took the piece and it fit perfectly over the shaft lever.
#40
i received my shift boot from Geordie yesterday. I will set up another mock up this morning when i get a chance. Any trick to putting the shift boot base back in there?
#41
I believe ETB was referring to the bottom of the page, where there are pretty good looking inserts for just the gears. If the original seller doesn't want to make the proper shift pattern ***** for us, buying the cheaper 901 **** and then gluing those inserts on top could work.
