Steering help
Steering help
I reconditioned my rack recently, with the help and advice on this forum (superb as always). I also replaced the inner and outer track arms and rod ends and boots, so it is 'as good as it can be' All of the mechanical parts I used were Lemforder, which I consider to be good make.
The problem is, when i turn into a bend at reasonable speed, the car turns great, then as the corner progresses i have to apply a lot more steering. Its like there is some wear or play in a dead zone of the rack, but the actual mechanical parts of the rack (rack and pinion) are in great shape.
Anyone come across this issue, is it a characteristic of the car?
IHI KING!
No, that's not normal. A few questions for you
1) Do you have the same brand and model of tires on the front and back?
2) How recent is your alignment?
3) What tire pressures are you running?
4) Have you checked your suspension bushings?
Hi Rob
Michelin PS2 all round (new)
Alignment 1 week ago
36 front 44 rear
All new poly bushed
Everything is new or refurbed.
And new PSS10 all round
Hope you come up with some ideas?
Allan
36 front 44 rear
All new poly bushed
Allan
IHI KING!
What diameter tires/wheels do you have? Are they 16" or 17"? If you are running 16", then your tire pressures are fine. If they are 17", then you should be running 36psi front and back.
Really? I have 17" cups and do the 36/44 with no perceived ill effects? What am I missing?
OP: Are we talking about understeer here? Or does it feel like the car's steering isn't reacting consistently? Do you have a C4? Are you invoking the rear diff lock?
Did you increase the caster when you put everything back together? Sounds like maybe you are running higher caster than before and therefore the difference?
Or is is a power steering issue? Hard to tell from the description if you are saying your power steering is the cause or if it's an alignment issue. 36-40 lbs pressure in the front tires wouldn't cause the steering to get noticeably heavier as you turn the wheel farther. That will only make a difference in over-all grip. But if you ran too high a pressure and had less grip as a result, your steering still wouldnt get heavier as you turn...
It feels like it needs too much turn of the steering wheel in relation to turn effect of the car. Initial turn of the wheel is fine but if you need to add more steering to go around the bend, you need to turn the steering wheel a lot. It does fee like understeer, but I'm not going fast enough to invoke understeer.
I drove it last night and was a bit more aggressive with my steering input. IE I turned later and harder in order to load up the front more and it seemed much better. Perhaps I need to adapt my driving style?
No its C2.
As Freedman says, you should be 36 psi all round for 17 inch tyres. The increased pressure you have at the rear will increase understeer. However saying that, it is probably more of a driving style thing that you are experiencing. Once you're in the turn adding more steering while on steady throttle doesn't do a lot because the weight will be back on the rear (the rear of a 911 will be dominating the line through the turn). To turn more whilst within the turn you need to ease back on the throttle to get some weight on the front so that the front tyres can dominate the turn.
These are same principles I've been taught for track driving. In fact, I've experienced at first hand that adding more lock when cornering can actually create more understeer. In this situation using the throttle to steer the car and taking some the steering lock off is the way to get round a corner quickly to prevent running wide on the exit.
I still don't understand. Are we talking about "at speed" where you are actually experiencing wheel slip or are you feeling this driving around town...
My understanding from the original post is that you are feeling it at slow speed...
