Rear blower causing rev related whine?
Hi everyone,
When my rear blower is connected I get a whining noise that changes with the revs of the engine. When I disconnect the rear blower it stops. Sometimes it doesn't start until around 2000rpms. I can hear the whining noise in the engine bay - it's not coming through the car speakers.
I'm thinking that it's the alternator that could be causing this - has anyone else experienced the same?
Thanks!
Andrew
Thanks!
Andrew
Yes, it's a high pitch whine - not loud, just there! It stared after I had the alternator replaced, but I don't know if that was a coincidence or if something in my blower was damaged when my old alternator lunched itself!
Had the same happen, after I replaced the paper ducts by the footwells. I thought I had misaligned the ducts, replaced them again, but still get a whine. It stopsd when I unplugged the blower motor though.
It is probably NOT your heater blower, but rather your engine fan belt sensor.
They die pretty commonly, you can take them apart and clean them, even tie them back out of the way to stop the noise--but god forbid your belt actually break--because you won't notice until you cook the motor.
Lol, this one is PARTICULARLY worn
the whine changes with the engine revs, so it's not the actual blower motor or it's bearings. It's got to be something electrical that's causing it.
Keep the suggestions coming though!!
Well, the blower motor has nothing to do with engine speed or revs, so my only thought is that you have air being sucked into the engine fan which then ducts over to the heater blower that is escaping somewhere. Either at this junction
Or at the other end where it meets the heat exchangers. Or possibly where the resistor or temp sensor fit into the duct along the pipe.
OK, the plot thickens..
This morning after going on a run to take my son to school I disconnected the blower power lead and the noise stopped - this was after putting the car in the garage without me stopping the engine. I've just been to take the below video and after starting the car again unplugging the blower doesn't stop the noise now, which makes me wonder if it's a charging thing since I'd just started the car. I'll try test the same thing tomorrow morning again to see if I can replicate it!
If you listen carefully you should be able to hear the noise. George and Johan - Is this the same as you're getting?
On mine, the noise, is very much a whistling one, like an air draft, and engine speed dependent. It does stop when I unplug the blower. It is not the belt tension thingy, I have checked it. It isn't the rubber connection on top of the alternator shroud either. Checked that too.
Andy, like in your vid, but very much audible in the car when driving.
