964 Forum 1989-1994
ABS light & No Speedo?
Old 09-16-2014, 01:08 AM
AC/911's
AC/911's's Avatar
Default ABS light & No Speedo?
So I took ECU out of a 93 964 to use in another 93 for a Minute, put back in & ABS light is on & Speedo does not work? Car runs fine, disconnected battery , ECU, still no change, Put Speedo back in Other Car works fine, back in Original car, lights up, but not speed or miles register & ABS light on, What are the chances it just started an ABS problem?
Tech came out with 2 Diagnostics & could not reset ABS system & get light to go off?
ANY HELP would be appreciated, Thanks
AC/911's is offline
Old 09-16-2014, 01:12 PM
BigKraut
BigKraut's Avatar
Have you tried replacing the ABS relay? Years ago my ABS light came on and the speedo quit working (and the odo, too?). Turned out to be a failed relay.
BigKraut is offline
Old 09-16-2014, 01:37 PM
AC/911's
AC/911's's Avatar
Will check that, Thanks
AC/911's is offline
Old 09-16-2014, 09:38 PM
J richard
J richard's Avatar
Hammer time...get a reset. I had the same problem thats all it took.
J richard is offline
Old 09-16-2014, 11:46 PM
AC/911's
AC/911's's Avatar
Default anti lock abs relay, speedometer
Hammer was a no go as I said, however, switched relay 33 (r33) & 34 (r34) & problem Fixed, Thanks for the help
AC/911's is offline
Old 09-16-2014, 11:47 PM
AC/911's
AC/911's's Avatar
closing
AC/911's is offline
Quick Reply: ABS light & No Speedo?
