Before and after Momo install
#31
Turn signal cancel seems to only work about 75% of the time now. Any body know why they don't kick off sometimes?
My installer took out the old horn contact ring. Is that supposed to come off?
#32
Did you get a new horn contact? It looks like this L shaped piece in the picture. Ignore the comment on it,just a quick google search.
https://rennlist.com/forums/attachme...n-contact2.jpg
#33
The finger on the back of the boss will have a crappy rounded edge on it, if you file a flat edge onto it, it will trip the switch to cancel the indicator. It must be slipping over the plastic switch same as mine was, quality on the back of the momo bosses isn't the best.
Ian
Ian
#37
Tanks for the pic. I dont *love* the tilted look personally. But....i am a little concerned that using the eccentric adapter will be weird,too. Google it and the is a funny video of some guy turning the wheel and it looks odd.
#38
I would think after a few days of driving, it would seem "normal"......
#40
I just installed my momo wheel and the turn signal turns off as it should. Maybe the tab is in the wrong place and not cancelling the turn signal when you turn the wheel.
#41
Jimony. Thanks for the reply. I am going back soon to install the eccentric hub. I will make sure to file the boss and install it on same side as turn signal stalks. Crossing my fingers it works!
#42
Boss on same side as stalk? I am trying to get turn signal to cancel.
Edit: yes, boss need to be on left. Now they cancel
