intermittent stalling and no fuel pressure 964
Just wanted to let you know, I have been chasing an intermittent stalling fuel pump issue for about two years. Changed two pumps, and a couple of DME relays.
Turned out the ground point for the pump, located on the passenger side of the trunk rail was very loose. This is a 30 second check point if you experience intermittent stalling, in your 964.
Pull the passenger side wall carpet, in the trunk. The ground point is about 3" from the front of the trunk, and 3-4" below the trunk/hood seal. There are ground points on both sides of the trunk. Worth a 30 second check.
