Low Oil Pressure causing me concern
#166
Have the engine pretty much built up and out and in the process of mounting the flywheel. After putting small torque on a few bolts to sit the flywheel in place, I went to turn the crankshaft to line up the hall sensor with the pick up (to set the gap) and couldn't turn it! Tried at the belts and the flywheel with no dice. Loosened the flywheel right off and was able to turn it. Is something binding up? Is this normal?
#170
Install went well. Issues with the tranny to engine but finally went with the loose clutch late method and it went well from there.
Will post this question here as well, with a rebuilt engine as well as an oil tank and oil cooler refurb, I expected that the car would take the normal amount of oil at first (6quarts/ litres) then a bigger top up to fill the lines and cooler once the thermostat opened. I did this, and have now put in a full 12 litres of oil into the system without the sensor budging. My question is for those that have done a rebuilt with all oil out, HOW MUCH OIL DOES IT TAKE TO REGISTER ON THE GUAGE?
Idle is hunting once warmed up. Thermostat opened up on queue. I'm finding it hard to read the dipstick to know where my level is..
#171
The gauge is hanging as a float at the top of the oiltank. So it more or less only is active when your near max. The range of the float is 1,7 liters, meaning the last 1,7 liters in the system.
#175
yes yes.
I have watched the oil temp climb, then drop, showing the thermostat has opened, then climb and settle out. I have not yet done a good long run and will do so once the safety passes.
#176
Well, I may have put on 100km on the rebuilt engine by now. Oil pressure at regular rpm is pinned high. My idle still fluctuates (fabspeed exhaust and cat bypass and chip combo) so I may have a bit of ISV research to do. Reason I mention, is that when the revs drop to almost 200 rpm, my oil pressure is just below 1, so I'm not worried any longer.
Car is at the garage for the safety today. Plated and ready to rock, 'cept I need to stay below 4500 rpm for first 2000km ack!
Thanks to all for the help on my project. I'll probably post a follow-up either here or elsewhere on my reinstall learnings, specially clutch alignment and engine-to-tranny hardships.
Engine purrs like she ought to.
Peter
Peter
