Intro and other shenanigans
#31
I bought a steve wong chip recently which is a little tricky to put in, but now that I know how to do it, I could do it in 15mins
I also decided to get rid of my rear wiper, I have driven the car in the rain a few times and I know I will never use it.
step 1 remove rear wiper motor etc
step 2 plug hole
easy
I also bought a pair of the aero mirrors to help update the look of the car, I will be installing them shortly
step 2 plug hole
easy
#33
turns out my engine has a broken headstud...
so the engine has to come out, which led me to remove the sound pad which was dry rotted
and after, I really don't know how anyone could do this without removing the engine, it was messy.
the engine out
this is where it is at currently
you can see the black part on the head where stud was broken, on the upper left hand
this head had some mild seperation on the left side as well, from the head bolts being stretched
I've decided to put in ARP head studs so they won't expand on me, Im also getting new cylinders & cylinder heads to update the engine to the 92.5+ 964 which had head gaskets to prevent leaks down the road and keep better compression numbers. I am also getting the head ported and polished. Basically this will be a new engine except for the small block. I am also getting every seal replaced so that once this thing is back together it will be reliable for a long long time. I am also considering powder coating a few parts like the intake manifold and the fan. Probably just go with a gloss black.
the engine out
#38
Wow, you've been through and done a lot to your 964 since you bought it last August!
Hope the kid is doing great too!
#39
Former Vendor
#41
May I ask a naive question, what does block stripped and cleaned entail and did the machine shop do that process?
Curious, where is all the tear down and build taking place, i.e., your garage?
#42
The Porsche shop doing the rebuild cleaned up it for me. By stripped I meant removed all accessories/wires/heads/cylinders down to the short block. Then it was wiped clean with a lot of paint thinner. The shop doing it is called Performance Automotive in Malvern PA. They have literally rebuilt hundreds of these engines and could probably do it with their eyes closed
#43
thanks, although I think I may have found another one I like better
Thanks, although I'm not the one doing the rebuild
#44
engine is almost done in these pics
I got the car back late last week, and she drives a LOT better than before. smooth idle and plenty of power. Feels like a lot more than before. The bad part is that its 10 degrees out, the roads are covered in salt and we are supposed to get 4 inches of snow tonight. In the garage it will stay...It seems like my Porsche was a little neglected when I got it, basically everything from the crank case out is new or rebuilt. I also had the AC updated to R143 since it had a leak before and r12 cost an arm and a leg. I'm feeling confident that I will have a lot of worry free miles ahead of me.
all back together.
all back together.
#45
Basic Sponsor
Coming along nicely! keep up the good work!
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
